Hello,
I have a question.
Is there a way to remove the OCR in a .pdf?
I want to keep the text, but I don't want people to find the text with the search button.
I can print the pdf to an image, but then the quality is to bad.
I have several pdf's in one pdf, made with Framemaker. see attached.
Does anyone have a solution?
regards
Pieter
Don't perform OCR on the documents.
How do you create a pdf without OCR
I can't find the right propertie
thanks
Don't enable OCR when scanning documents.
And when I print a pdf file?
Then you will get a printout.
If you are printing, OCR is not active. It can only be automatically activated with scans. Printed PDFs should not be able to be OCR'd as they are generally a mix of graphics and text. If you want a graphic version, then do the save a TIF, then import the TIFs back into Acrobat to get the graphic version. Can't understand why you would want to do that, but it should do the job.
Try file>Export>Image. Choose .tif. Create a new PDF from that .tif.
Simple...
Step 1:
"Document" > "Examine Document..."
Step 2:
In the "Examine Document" panel, select "Hidden text (xx pages)" under "Results".
Step 3:
In the "Examine Document" panel, click "Remove".
Step 4:
*hi5*
Note: I'm using "Adobe Acrobat 9 Pro" version 9.4.5.
