Using CFFTP
Jul 05, 2006 Jul 05, 2006
I need to pull multiple files of various type from an ftp server. All files are pulled from the same folder.
These are files supplied by a content provider and I basically need to pull all these files down once a week to a local directory.
I figured out how to grab one file at a time and store it in the appropriate folder, but I want to just be able to pull all the files from the folder regardless of name and regardless of how many files there are.
Any advice would be appreciated.
Thanks.
Scott
Advanced techniques
468
Guest
You should be able to loop though and just use the getFile to copy all the files you need.
An example:
<CFSET newFeedDir = GetDirectoryFromPath(GetTemplatePath()) & "test\">
<cfftp action="listdir"
username="****"
password="****"
name="feedDir"
server="test.com"
transferMode="binary"
failIfExists="No" directory="/">
<CFFTP CONNECTION="myConnection"
USERNAME="*****"
PASSWORD="*****"
SERVER="test.com"
ACTION="Open">
<CFLOOP query="feedDir">
<CFFTP connection="myConnection"
ACTION="GetFile"
NAME="qryFTP"
TRANSFERMODE="Binary"
FAILIFEXISTS="No"
LOCALFILE="#newFeedDir##Name#"
REMOTEFILE="/#Name#">
</CFLOOP>
Contributor ,
You could use CFDIRECTORY to get a list of all the files in the directory, loop through the list and download the file.
See
http://livedocs.macromedia.com/coldfusion/7/htmldocs/wwhelp/wwhimpl/common/html/wwhelp.htm?context=C...
Jul 06, 2006 Jul 06, 2006
James74, cfdirectory is for local file transfer, whereas Scott wishes to get the file from a remote FTP server. It's a natural oversight that happens to all of us.
Amers, your code is the kind I would use. Shouldn't the second cfftp tag, with action="open", come first? Also, should there be a forward slash in the value of the RemoteFile attribute? I would suggest ending the code with the cfftp tag,
<cfftp action="close" connection="myConnection">
Guest
BKBK, you're right.. you do want to close the connection after you're finished. Also, basically under remotefile - you should put whatever the directory structure is on the other side. In this case, I used "/" - because I had actually used this in a script I wrote.
Thanks a bunch all!
I got everything working perfectly thanks to your advice!
Guest
BKBK's right about CFDIRECTORY. But you could use <CFFTP ACTION="listdir" ...> on the remote server to achieve the same results.
Documentation
