Hello,
If you go to this page:
On Step 1 – Create And Insert a Concept, at the end of number 3. Select Tools>Concept>Concept Window or press SHIFT+F9 on your keyboard the Concept window pane opens, there is a toggle button with a right arrow. If you press this arrow, a thumbnail appears below. Then, if you hover the pointer over the thumbnail, you get the full size screenshot. Is there a way to do the same with RoboHelp?
If there is, I would appreciate any hints as to where I could find some sort of step by step explanation. I can't find it in RoboHelp 8's online help nor in the PDF. And if there are no such things, at least the keywords for the main functions of the procedure.
Thanks a lot,
Daniel
Hi Daniel
I saw some other replies but when I actually logged in to post, they went missing.
Anyhoo, Colum advised on the Twisites issue. That's a small part of it. Willam advised on Walter Zorn's tooltip script at
http://gualtierozorni.altervista.org/tooltip/tooltip_e.htm
Anyhoo, I'm posting to offer a more complete picture. The actual effect is called a DHTML Drop Down in RoboHelp. That's what the effect is in RoboHelp that allows clicking a link and revealing a hidden element just below where you
...Copy link to clipboard
You need to read the Twisties page on Peter Grainge's site. Click here to do just that.
The RoboColum(n) | @robocolumn | Colum McAndrew |
I've deleted the duplicate thread. You only need to ask once in the RoboHelp forums.
The stuff on my site will not give you previews by hovering but you will get something that should do the job. There are javascript methods you can find by Googling for what you do want but don't assume they will all work in RoboHelp. You will need to test them.
Twisties might not be what you are looking for. To create a mouseover effect, try Walter Zorn's tooltip script. The script and instructions on http://gualtierozorni.altervista.org/tooltip/tooltip_e.htm
Greet,
Willam
Hi Daniel
Anyhoo, I'm posting to offer a more complete picture. The actual effect is called a DHTML Drop Down in RoboHelp. That's what the effect is in RoboHelp that allows clicking a link and revealing a hidden element just below where you clicked.
Cheers... Rick
Thanks to all of you for your helpful feedback.
I really appreciate it.
Daniel
Hi Rick,
Cheers... Rick
Thank you. That's what I was actually looking for. I don't want to do any Java scripting.
But how does the DHTML drop-downs work? In the main menu, under DHTML, there is the Create DHTML drop-down and text command, but it is dimmed. Do I have to create something first? Is there a place where this function is explained in a procedural way? I can't find a step by step example in the online user guide.
Thanks and kind regards,
Daniel
Select some text or an image that will be the hotspot. Then the option will be enabled.
Rick,
Don't worry anymore. I found the solution.
Thanks a lot again to all,
Daniel
