5 Replies Latest reply on Jan 19, 2012 4:29 PM by Chaos7703
    How to disable a tab in a spark tab bar?
    Handycam Level 1
      I have a spark tab bar linked to a ViewStack.  In olden days, IIRC,  setting the enabled property of a viewstack member would set the corresponding tab inactive.  However, if I try that now, the tab control is still active, but the contents of the viewstack for that tab is indeed disabled.
      To reiterate:  I want certain tabs in a spark tab bar to be disabled (i.e. unable to be chosen and displaying their disabled skin state).
      <s:TabBar id="tabBar" dataProvider="{tabStack}" x="70" y="91" skinClass="CalculatorTabsSkin"/>
      <mx:ViewStack id="tabStack" width="100%" height="100%" creationPolicy="all" change="tabStack_changeHandler(event)">
           <s:NavigatorContent id="nc1" label="PIERS">
           <comp:Tab1 id="tab1"  width="100%" height="100%" continue="tab1_continueHandler(event)" />
           </s:NavigatorContent>
           <s:NavigatorContent id="nc2" label="FOOTINGS">
           <comp:Tab2 id="tab2" width="100%" height="100%" continue="tab2_continueHandler(event)" numberOfPiers="{totalNumberPiers}" />
           <s:NavigatorContent id="nc3" label="BAGS OR TRUCK?">
           <comp:Tab3 id="tab3"  width="100%" height="100%" totalCubicYards="{totalCubicYards}" totalNumberBags="{totalNumberBags}" />
      </mx:ViewStack>
        • 1. Re: How to disable a tab in a spark tab bar?
          lenny fontes Level 1
          I'm faced with the same situation. Instead of enabling and disabling the tab, I've been forced to remove the offending tab when not needed.
          To do this in my case was simple (it was only 1 tab)
          I built the "removable tab's" NavigatorContent object in declarations;
          private function setTab(tf:Boolean):void
              if (tf){
                    viewStack.addChildAt( navContent, 0);
              } else{
                    viewStack.removeChildAt(0);
          This doesn't "resolve" my issue; but it has allowed me to continue on with development until Adobe addresses this oversight.
          • 2. Re: How to disable a tab in a spark tab bar?
            Handycam Level 1
            Here's how I solved my issue.  I used a button bar for the tabs, and in the button bar button skin, start it with
            <s:Skin xmlns:s="library://ns.adobe.com/flex/spark" xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:d="http://ns.adobe.com/fxg/2008/dt" width="150" height="30" creationComplete="init()" >
                 <fx:Metadata>
                      [HostComponent("spark.components.ButtonBarButton")]
                 </fx:Metadata>
                 <fx:Script>
                      <![CDATA[
                           import mx.events.FlexEvent;
                           private function init():void
                                hostComponent.addEventListener(FlexEvent.VALUE_COMMIT, onDataChange);
                                onDataChange();
                           private function onDataChange(event:FlexEvent=null):void
                                if (hostComponent.data.hasOwnProperty("enabled"))
                                     hostComponent.enabled = hostComponent.data.enabled;
                 </fx:Script>
            etc...
            By doing this, I could then set the enabled of the navigator content inside my viewstack as needed:
            <s:NavigatorContent id="nc2" label="Footing" enabled="false">
                 ... stuff...
            Hope that is helpful
            • 3. Re: How to disable a tab in a spark tab bar?
              Jorge Raimundo Level 2
              I solved it by binding the ButtonBarButton's enabled property to the NavigatorContent's enable property inside the TabBarSkin:
              <s:Skin
                  xmlns:fb="http://ns.adobe.com/flashbuilder/2009"
                  alpha.disabled="0.5">
                  <fx:Metadata>
                      <![CDATA[
                       * @copy spark.skins.spark.ApplicationSkin#hostComponent
                      [HostComponent("spark.components.TabBar")]
                  </fx:Metadata>
                  <fx:Script  fb:purpose="styling" >
                      ... the AS code ...
                  </fx:Script>
                  <s:states>
                      <s:State name="normal" />
                      <s:State name="disabled" />
                  </s:states>
                  <!--- @copy spark.components.SkinnableDataContainer#dataGroup -->
                  <s:DataGroup id="dataGroup" width="100%" height="100%">
                      <s:layout>
                          <s:ButtonBarHorizontalLayout gap="-1"/>
                      </s:layout>
                      <s:itemRenderer>
                          <fx:Component>
                              <s:ButtonBarButton skinClass="skins.tabBar.ConsusTabBarButtonSkin" enabled="{data.enabled}"/>
                          </fx:Component>
                      </s:itemRenderer>
                  </s:DataGroup>
              </s:Skin>
              Hope it helps,
              Jorge
              • 4. Re: How to disable a tab in a spark tab bar?
                Chaos7703 Level 1
                For those who want an working answer for Flex 4.5 (probably Flex 4 also).  I finally figured out a solution.  It feels like a hack to me, but it's working for me.  Here's a simplified example.
                    <!-- component that has the the TabBar in it... -->
                    <fx:Script>
                        <![CDATA[
                    //imports here
                    import mx.core.UIComponent;
                    //other imports
                    private function setTabEnabled(index:int,enabled:Boolean):void{
                              var theTab:UIComponent = theTabBar.dataGroup.getElementAt(index) as UIComponent;
                              if(theTab){theTab.enabled = enabled;}
                    </fx:Script>
                    <s:TabBar id="theTabBar"
                              dataProvider="{viewStack}"/>
                    <mx:ViewStack id="viewStack">
                        <s:NavigatorContent label="0th Tab">
                            <!-- ...Content -->
                        <s:NavigatorContent label="1st Tab">
                            <!-- ...Content -->
                        <s:NavigatorContent label="2nd Tab">
                            <!-- ...Content -->
                    </mx:ViewStack>
                    <!-- rest of the component that has the the TabBar in it... -->
                Then you just call `setTabEnabled(theTabIndex,trueFalse)` in an event handler related to whatever decides why the tab is, or isn't, enabled.
                I *should* extend the TabBar to support this, but I've already spent enough time trying to figure it out.
                Happy Coding =D
                • 5. Re: How to disable a tab in a spark tab bar?
                  Chaos7703 Level 1
                  Addendum:
                  Literally two minutes after I got back to actually working, I found a more "elegant" solution.  I posted it elsewhere, but I guess I forgot to share it here. =/ So I thought I'd update this real quick. =)
                  If you apply a custom skinClass to your tab bar you can bind the tab.enabled property just like you'd expect/want.
                  <!-- some component that has the TabBar in it... -->
                      <fx:Script>
                           <![CDATA[
                      [Bindable] private var tab2IsReady:Boolean = false;
                      private function checkCriteria():void{
                           tab2IReady = someOtherThing.isFinished;//Boolean
                      </fx:Script>
                     skinClass="skins.CustomTabBarSkin"/>
                        <s:NavigatorContent label="Tab index 0">
                             <!-- Your first tab's content -->
                        <s:NavigatorContent label="Tab index 1" enabled="{tab2IsReady}">
                             <!-- Your second tab's content -->
                  </mx:ViewStack>
                  When you type "skinClass" use the auto complete to generate the custom skin (named whatever you want).
                  The generated code will appear like below (I left out the Script tag).
                  <?xml version="1.0" encoding="utf-8"?>
                  <!-- skins/CustomTabBarSkin.mxml
                  Adobe's copyright & doc comments
                  <s:Skin
                      <fx:Metadata>
                          <![CDATA[
                      </fx:Metadata>
                        <!-- optional Script tag here -->
                      <s:states>
                      </s:states>
                          <s:layout>
                          </s:layout>
                          <s:itemRenderer>
                              <fx:Component>
                                  <s:ButtonBarButton skinClass="spark.skins.spark.TabBarButtonSkin" />
                              </fx:Component>
                          </s:itemRenderer>
                      </s:DataGroup>
                  </s:Skin>
                  <!-- End skins/CustomTabBarSkin.mxml -->
                  Then add the enabled property to the ButtonBarButton & bind it to data.enabled in your skin class.
                  Change:
                             <fx:Component>
                         </fx:Component>
                  To:
                             <fx:Component>
                                  enabled="{data.enabled}" />
                       </fx:Component>
                  Then any <s:NavigatorContent/> used with a TabBar using that skin will respect the enabled property and do exactly what you expect & want (be enabled when true, & disabled when false).
                  Hope this helps some people.  WIsh I'd remembered to re-post it here when I first figured it out.
                  Happy Coding! =D
                  Todd
                  Message was edited by: Chaos7703 - Just made one statement a bit more explicit.
