I need to know if I can cahnge the dpi of gif gile created when I save my frame files out as xml. I am using Frame 8 and it only saves out the gifs at 72dpi. I need a higer resolution. Does Frame 10 offer this capability?
Hello bkp-FEC,
You can increase dpi in Framemaker 10
On the right panel of the window under Object Properties, Click on Set dpi
Here are the screenshots
Hope It Helps!!!
Vishal,
Thank you for the information, but I don't think it applies to my question. The screenshots look like the dpi you set when importing graphics - my question was when creating xml from Frame, can you set the dpi for the output gif files that are created. The default dpi for gifs generated when creating xml is 72 dpi, which can't be changed in Frame 8. Can the dpi in the output gifs be changed when creating xml in Frame 10?
Bryan
