Does anyone know if it's possible to specify the width of the Title and Rank columns which display the FTS results? At the moment they look like they're 50/50. I'd like to make the Title column as wide as possible and squeeze the Rank column up. Also, can I change the symbol used to sort the columns to an image?
I've had a nosey in whfhost.js, but no joy.
Jonathan
Just to summarize what is mentioned in the specified thread and answer the second query of inserting an image for sorting...
For reducing Rank column width
1. Search for the function writeTableHead in the file whfhost.js
2. Look for TD ID='OdinFtsRank'. Out of the two occurrences, update the width value of the second one as required.
For example <TD ID='OdinFtsRank' CLASS='fr_tt' STYLE='cursor:pointer; width:15%;'>
This should reduce the column widht value.
For using an image for sorting columns
1. Loo
...Copy link to clipboard
This post might help.
1. Look for definitions of gsAscendFlag and gsDescendFlag on Line No 29 and 30 as ascending and descending sorting respectively.
2. Replace their values with img tag with necessary attributes. For exmaple: Something like this
gsAscendFlag = "<img src=\"down_arrow.gif\" />"
Please specify the image path accordingly and do enlose the path with \" --- \" as shown in the example.
I hope this resolves the issue.
Mayank
That's brilliant thanks!
I've also removed the Rank column (mentioned in this thread http://forums.adobe.com/thread/660831). However, when the Rank column isn't displayed, the ascending/descending image doesn't display until you click the Title column header. I'm guessing it still thinks the Rank column is the default sort column. Don't suppose you know how to change this to the Title column so that the image is displayed straight away?
Cheers
Jonathan
This happens becuase, initially the results are displayed sorted by rank columnn which is hidden in your case. They are sorted by Title only when Title header is clicked.
You can update the sorting type so that the initial sorting also happens based on Title.
Update the value of g_nSortType from 0 to 1 at line 49 to change the sorting from Rank basis to Title basis.
var g_nSortType = 1;
Mayank
Once again, your advice worked a treat!
Many thanks Mayank
Jonathan
Actually Mayank, before I let you go. Do you know how I can style the seach progress bar or even replace it with an animated gif?
Jonathan
@Jonathan. It will be great if you could start a new discussion in a separate thread. Also, it will be helpful for others if you could mark the helpful response in this thread as Answer so that others can refer it directly.
@Leon. Please try following all the steps mentioned in this thread. It should work for you. Or you can mention the exact steps you followed and exact problem you faced.
No probs, I've started a new thread here: http://forums.adobe.com/thread/794899?tstart=0.
I've marked the thread as Answer too.
Thanks again, you've been a real help!
Jonathan
The exact steps I followed and the exact problem I faced?
The problem I faced with step 3 was this: your instructions resulted in no change to the default behavior. With a search that produced 18 results:
Leon
Ideally the solution should work as per the steps followed by you.
It will be great if you could share the whfhost.js file on your system so that I can look into the exact issue. You can mail me at magrawalATadobeDOTcom
Mayank.
The change to line 49 didn't work for me, Mayank. The titles are still sorted by Rank.
Leon
Hello Mayank,
I was just faced with the same problem and found your solution, tried it out and ... it works!! Thanks a lot.
Greetings from Switzerland,
Kurt
