How can I connect to a web service that required SSL V3.0
client certificates using CFMX?
I'm trying to use a client certificate to connect via CFHTTP
to a secure website and I'm getting a "403.7 - Forbidden: Client
certificate required" error. I correctly installed the website cert
using the instructions here:
http://www.talkingtree.com/blog/index.cfm?mode=entry&entry=25AA75A4-45A6-2844-7CA3EECD842DB576
When I access the secure site using IE, I'm prompted to use
the installed client certificate and then I am able to view the
secure content without any 403 errors.
After continuing to research the issue, I read in this post
that CFMX7.01 doesn't support SSL V3.0 protocol:
http://www.houseoffusion.com/cf_lists/message.cfm/forumid:4/messageid:229870/step:0
Is anyone using SSL V3.0 client certificates with CFMX7.01?
Is this an Adobe issue or java issue? Are there any work-arounds?
