1. Re: overlapping paragraphs?
P Spier Feb 22, 2011 6:29 AM (in response to phyllisj9)One thought that comes to mind would be to split the story into two threaded frames at that break, then overlap the frames.Putting the second paragraph in an anchored frame with text wrap applied might also work, but it would be a lot harder to edit, in my opinion, down the road.
But hang out for a while, there may be more sophisticated ideas from Peter Gold or Jongware (Peter in particular has some clever ways to mimic feturess that were availble in FrameMaker that are missing in ID).
2. Re: overlapping paragraphs?
[Jongware]-9BC6tI Feb 22, 2011 6:34 AM (in response to P Spier)I'll gladly hand this over to Peter G. -- I'm clueless.
3. Re: overlapping paragraphs?
peter at knowhowpro Feb 22, 2011 7:48 AM (in response to P Spier)P Spier wrote:
AAAAAARRRRRRRGGGGGGGGHHHHHHH! This is what I get for becoming known for being clever! I'll be careful what I wish for in the future.<G>
FrameMaker has a paragraph property called "run-in." A run-in paragraph has a paragraph end property - with hidden characters ON, it looks like an ordinary pilcrow (¶), but it's only a paragraph end, not the common combination of paragraph end (AKA "carriage return") and a new line (AKA "line feed.")
Because it doesn't start a new line, the following paragraph begins immediately after the paragraph end. It's terrific for heading paragraphs introduce body paragraphs right after, but they don't consume a line of depth, therefore saving paper, while also making a smoother connection for readers between an introduction to a topic, and the topic itself. Another major benefit is that, being a paragraph, it can be extracted to a TOC!
InDesign's nested-character and GREP paragraph styles can format a paragraph's beginning differently from the remainder, but they can't be extracted for a TOC. If you like how this feature sounds, submit a formal request for run-in paragraphs, and character-style-based TOC extraction at https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform.
FrameMaker drops the user-specified default trailing punctuation of run-in paragraphs when they're extracted to a TOC, but if the user manually types in trailing punctuation, it's retained in the TOC.
Cool, eh?
I was going to suggest the overlapping text frame approach that Peter S. already did. You can indent the first line of the overlaid paragraph to a fixed position, but, as Peter S. notes about text wrap, later editing may need manual attention.
As long as manual effort might be needed, you might want to manually type new paragraph content on the last line of the first paragraph and start the next paragraph normally. You might want to apply a "featureless" character style to the manually-typed content, either manually, or via a nested style, so you can find it quickly for later editing.
HTH
Peter
_______________________
Peter Gold
KnowHow ProServices
4. Re: overlapping paragraphs?
phyllisj9 Feb 22, 2011 9:05 AM (in response to peter at knowhowpro)Wow, I guess that was a more complicated question than I expected! Thought maybe I was missing something obvious. Thanks for the ideas on different frames etc. I hate that it couldn't be all one frame, but the manual effort would proably make this look better. But the Framemaker run-in property sounds like it's what I really need!!! That would have been perfect for this. Drat.
Thanks, Phyllis
5. Re: overlapping paragraphs?
peter at knowhowpro Feb 22, 2011 10:23 AM (in response to phyllisj9)phyllisj9 wrote:
Thanks, Phyllis
Does "drat" mean "I'm really going to file a formal feature request with Adobe?"
Peter
Peter Gold
KnowHow ProServices
6. Re: overlapping paragraphs?
phyllisj9 Feb 22, 2011 11:28 AM (in response to peter at knowhowpro)peter at knowhowpro wrote:
Hah! I get the impression that's just a black hole, though maybe I should.
Thanks, Phyllis
7. Re: overlapping paragraphs?
peter at knowhowpro Feb 22, 2011 12:52 PM (in response to phyllisj9)phyllisj9 wrote:
Thanks, Phyllis
It's a black hole if you expect instant results, or even results in the next release. However quantity matters - the more votes for a feature, the more likely it will happen sometime. Do the InDesign community a service, and yourself a favor, and post a request.
Peter
Peter Gold
KnowHow ProServices
