13 Replies Latest reply: Mar 3, 2011 9:09 AM by Larry G. Schneider RSS
    Stacking Multiple Artboards?
    hoovdan Community Member
      Hi everyone,
      I am trying to write a script that will take all the artboards in a document and stack them on top of each other.  (All the artboards are the same size).  It will also bring all the artwork on those artborads along with it.  And then it will delete all the artboards except one.
      So far I have thought of two ways to accomplish this:
      1)  document.rearrangeArtboards() - This function allows you to arrange the artboards by grids or rows, but as far as I can tell, you can't make them stack on one another...?
      2)  document.selectObjectOnActiveArtboard() - selects all artwork on one artboard, then...
          [some function to move all artwork to position of first artboard, and then repeat for all artboards]
      Any ideas on how best to go about this?  I would really appreciate your help!
      Thank you!
        • 1. Re: Stacking Multiple Artboards?
          CarlosCanto Community Member
          go with # 2, no need to move the artboard, just move the pageItems then delete the arboard
          do you want to learn how to do it? here's how, it's more fun if you do it yourself
          1. loop thru the Artboards (from last artboard to second artboard)
          2. activate artboard
          2. select all with selectObjectsOnActiveArtboard
          3. find the distance from active artboard to artboard # 1 (use artboardRect property)
          4. loop thru all items in selection
          5. move item to first artboard (based on distance found in #3)
          6. deselect item
          7. delete artboard
          I'll post the actual script if you get stuck.
          • 2. Re: Stacking Multiple Artboards?
            Muppet Mark-QAl63s Community Member
            I would agree with Carlos the only thing I would look at adding is the moving of each artboard's contents into a new layer's contents as Im not sure how the stacking order will be affected by the art translation… Could get very messy very quickly… But I suppose that all depends on your art…
            • 3. Re: Stacking Multiple Artboards?
              Thank you both for your responses!
              Carlos, that was exactly the logic I had in mind for option 2.  Here is my attempt (I am unsure how to accomplish the bolded part):
              #target Illustrator
              var docRef = app.activeDocument;
              stackArtboards();
              //------Stack Artboards and Contents-------------//
              function stackArtboards(){
                 var activeboard = new Array();
                 var stackhere = new Array();
                 var getdelta = new Array();
                 var numboards = docRef.artboards.length;
                 stackhere = docRef.artboards[0].artboardRect;
                 for(i=1; i<numboards; i++){
                      activeboard[i] = docRef.artboards[i].artboardRect;
                      getdelta = calcDelta(stackhere, activeboard[i]);
                      var deltaX = getdelta[0];
                      var deltaY = getdelta[1];
                      docRef.artboards.setActiveArtboardIndex(i);
                      docRef.selectObjectsOnActiveArtboard();
                      <<insert "move selected items" function here>>>
                      delBoard(i);
              //------Calculate How Much to Move Artwork-------------//
              function calcDelta(stckhere, movethis){
                     var deltaX = stckhere[0] - movethis[0];
                     var deltaY = stckhere[1] - movethis[1];
                  return[deltaX, deltaY];
              //-------Delete Artboard-----------//
              function delBoard(boardindex){
                  docRef.artboards.setActiveArtboardIndex(boardindex);
                  docRef.artboards.remove(boardindex);
              As you can see, I couldn't find a good way to move artwork that has been selected.  This artwork isn't always on the same layer, and it contains text items, path items, groups, linked files, you name it, so any code examples would be appreciated!
              And now for all those Adobe employees that I hope are lurking in this forum:
              I have some Javascript experience but I've never coded scripts for Adobe programs before.  So naturally in order to learn how to start scripting, I turned to the Object Model Viewer.
              After much poking around in the Object Model Viewer, I have decided it is not very helpful at all.
              For starters, the "copy text" link copies all of the text in the description box, instead of copying the sample code to actually call the function or property I am looking up.  I don't need the whole paragraph with all of the descriptions in my code, just copy a line of code that would be the same as if I let ESTK autocomplete when I type.
              Secondly, the OMV only displays the default arguments of a function when it would be much more helpful to include all the options for each argument (i.e. the entry for "document.rearrangeArtboards" does not list all the options for the "artboardlayout" argument so I do not know what options there are for this function until I go back to ESTK).
              Thirdly, the OMV should also provide example code for how to use this function or property, even if it was very simple.  It would be great to see a short block of example code that really showcases this function's/property's purpose.
              And lastly, there is some sort of bug when I have OMV and ESTK open and I try to switch back and forth between the two.  The OMV will stay on top of all the other windows even when I Alt+Tab back and forth two or three times or even clicking the ESTK on the taskbar.  It takes a couple of tries to get the ESTK as the active window.  I am using CS5 on Windows 7 64-bit.
              Thank you all for taking the time to help me out!
              • 4. Re: Stacking Multiple Artboards?
                no problem,
                what you have so far kind of works, it starts with the second artboard and when it gets deleted, the third artboard becomes the second. So when it loops to the next AB the 3rd is AB # 4, does it makes sense? you need to start with the last AB so when it gets deleted the others don't get their index # messed up.
                loop backwards
                For i = idoc.Artboards.Count To 2 Step -1
                to move items use a translation matrix
                Set moveMatrix = iapp.GetTranslationMatrix(deltaX, deltaY)
                loop thru items (any kind of item) in selection, and apply matrix
                sel = idoc.Selection
                For j = LBound(sel) To UBound(sel)
                    sel(j).Transform moveMatrix
                    sel(j).Selected = False //deselect
                Next
                it's all VB code, but you get the idea.
                As Mark said, it could get messy once all is in one artboard, but I guess they are all arranged to coexist into one, right?
                • 5. Re: Stacking Multiple Artboards?
                  Oh many good points, Carlos.  Thank you for catching that!
                  And yes, although it will turn out quite messy, that is kind of the end goal.  You see, I am trying to develop a script that will take an Illustrator file with many artboards and prepare it for animation with After Effects.  Currently, I receive an Illustrator file that has many artboards on it.  The artboards are the designers way to communicate how the animation should proceed.  They are bascially storyboards with each artboard slightly changing its appearance and content from one to the next.  It looks like a flipbook all layed out.
                  But After Effects will only import one artboard and so everything in the Illustrator "storyboards" needs to be moved to one artboard.  Then the script will turn all the groups/artwork/linked files into their own "top level" layers because After Effects will merge everything that is in one Illustrator layer, which prevents me from being able to independently animate the separate artwork pieces.  And then since I only need one instance of each piece of artwork to use in After Effects, I will have it delete any artwork that doesn't change size/position/rotation from one artboard to the other.  I will probably have to designate these "duplicates" manually by making them invisible in the Layers panel and then having the script delete all invisible layers.
                  If I can get this to succesully run, it will easily save me anywhere from 2-4 hours per day.  Right now I have to manually drag everything around, reorder all the layers, and pull sublayers out to their individual top level layers, and it's just tedious.
                  But back to step 1 in my plan for world domination automation.
                  I had seen the getTranslationMatrix() function, but I never could get it to work. I'm not quite sure what you mean by LBound(j) and UBound(j) in your script.  Maybe you can explain a little more what it is doing?  Or maybe write it in Javascript instead?
                  Here is my updated code:
                  #target Illustrator
                  stackArtboards();
                     for(i=numboards; i>1; i--){
                          activeboard[1] = docRef.artboards[1].artboardRect;
                          getdelta = calcDelta(stackhere, activeboard[1]);
                          docRef.artboards.setActiveArtboardIndex(1);
                          var sel = docRef.selection;
                          var moveMatrix = app.getTranslationMatrix (deltaX, deltaY);
                          sel.transform(moveMatrix);
                          sel.selected = false;
                          delBoard(1);
                  When I run this script, I get an error at the bolded section (sel.transform(moveMatrix);) - it says "sel.transform is not a function."  Since I'm not quite sure what your VB script is doing, I'm not exactly sure how to proceed.
                  I appreciate your help!
                  • 6. Re: Stacking Multiple Artboards?
                    Lbound & Ubound are the VB functions to get the first and last index of the selection, there's no "length" property in VB.
                    loop thru all items in selection and apply matrix
                    for (var j=0;j<sel.length;j++)
                              sel[j].transform (moveMatrix);
                              sel[j].selected = false;
                    this should set you on your World Dominance way.
                    • 7. Re: Stacking Multiple Artboards?
                      Perfect!  It could not be better!  Thank you so much for your help!
                      I know I always appreciate threads where the code was posted with final updates once it works, so here you go, future Googlers!
                      #target Illustrator
                      stackArtboards();
                              for (var j=0; j<sel.length; j++){
                              delBoard(1);
                      • 8. Re: Stacking Multiple Artboards?
                        If you are not a fan of the OMV then you could try Jongware's helpers… See:
                        http://forums.adobe.com/message/2928285#2928285
                        • 9. Re: Stacking Multiple Artboards?
                          Hi Mark, thank you for the link!  That looks to be very helpful, except that when after I downloaded the CHM file for Illustrator CS5, it would not display any content, even though the index in the help file was there.
                          Here is a screenshot:
                          Any ideas why it won't display properly?
                          • 10. Re: Stacking Multiple Artboards?
                            Ooo that looks a little different to mine… I would surmise thats down to me being on a mac and having the use the recommended viewer… (Which works very well for me). It would be far better for Jong to advise you as he created these. What is very nice is the speed in which you can search them and the easy to follow object hierarchy. Bump his post just in case he's not following this topic…
                            • 11. Re: Stacking Multiple Artboards?
                              it works fine here, I'm on windows too, try downloading again. Or before that try opening any other chm file already in your system to see if it works.
                              • 12. Re: Stacking Multiple Artboards?
                                Hey guys, thanks for the responses.  I'm about to bump his post, but I figured I'd post here too.
                                It seems that the downloaded .chm file from his website carries some sort of security warning that other .chm files that are installed on my computer do not have.  Even if I click OK, I have a suspicion that my computer still has some sort of security measure turned on that is blocking the content.
                                Here is the security warning I get before I open his file:
                                When I click Open, the Index/Table of Contents are all there, but none of the pages can be displayed, it looks like this:
                                Compare this to a "trusted" .chm file (Microsoft Security Essentials) that doesn't require a Security dialog box:
                                Strange isn't it?
                                Thanks for your help!
                                • 13. Re: Stacking Multiple Artboards?
                                  Larry G. Schneider CommunityMVP
                                  One other minor detail. You can't delete a layer that's hidden. You will need to loop through reversing all the visibility, then select the visible layers and delete, then reset the visibility of the remaining layers to true.
