How could I delete automatically the unused paragraphs and character styles from the catalogs?
PGF Whopper, free from Cudspan, does the job on most versions of FrameMaker. I have found the character side of it doesn’t work in version 9 – although I see from the site that there is a new version. Give it a try.
David,
I downloaded it and placed the file in my plug-in folder, but it doesn't show up under File>Utilities. Is there anything else I should do?
I am running FM9 with all updates.
ls
Did you restart FrameMaker?
Yes, but not the computer. Guess I should try that.... I already did that
once today though, and it take a little while...lol
ls
Thank you David
Are you using FM9? I have downloaded it 2 times
and restarted FM and my computer, but it still doesn't
come up in the utilities folder.
What am I doing wrong?
ls
Does View> Menus> Complete make any difference?
Yea!!! Thank You!! I did have it set for complete, but chose customize and
saw that the file wasn't in that plugin folder that FM was looking at. I had placed
it in the plugins folder directly under FM9. I moved the file to the correct plugin folder under
FM9/fminit, restarted FM and it is there...now to use it...likes a bunch!!
ls
I collected from the discussion that you are not using FrameMaker 10.
I shall mention that it is a breeze doing so in FM10. Check it here: http://twtools.wordpress.com/2011/02/05/unused-formats-in-framemaker/
regards
