1. Re: Getting 503 errors for f4f httpstreaming files
electroteque1 Feb 19, 2011 5:40 PM (in response to electroteque1)I'm unsure why some people get it and other people don't . i was even using the demo FMS files to package with. Any ideas ? Bug report is my next option.
2. Re: Getting 503 errors for f4f httpstreaming files
AbhishekSinha Feb 22, 2011 9:12 PM (in response to electroteque1)Hi,
The output on inspect-fragment looks correct and it seems file has been packaged correctly. It seems like your F4F module is not installed correctly. Can you verify your logs and see if you get an idea.
Abhishek
3. Re: Getting 503 errors for f4f httpstreaming files
electroteque1 Feb 22, 2011 9:20 PM (in response to AbhishekSinha)Hi thanks for your response, appreciate it. No generally an apache module would log a stacktrace, this plugin doesn't log anything which doesnt help. Is there a development binary module with logging enabled I could try out ? I am running this on ubuntu 64bit linux.
My next steps is to try strace debugging apache.
4. Re: Getting 503 errors for f4f httpstreaming files
electroteque1 Feb 23, 2011 12:15 AM (in response to AbhishekSinha)Hi there FYI.
I used strace to figure out the issue. Your module does not log file not found errors correctly.
Here was the original config
<Location /videos/vod>
HttpStreamingEnabled true
HttpStreamingContentPath "/var/www/httpstreaming.electrocode.net/web/videos/vod/f4f"
Options -Indexes FollowSymLinks
</Location>
http://httpstreaming.electrocode.net/videos/vod/f4f/sample1_700kbpsSeg1-Frag1
And I was requesting it like this therefore in the stacktrace I saw there was filesystem errors saying the file cannot be found. it was requesting it like
/var/www/httpstreaming.electrocode.net/web/videos/vod/f4f/f4f/sample1_700kbps.f4vI suggest put some logging in the module as a feature request perhaps, to prevent others having to strace their apache servers to figure what the module is doing wrong ! -
5. Re: Getting 503 errors for f4f httpstreaming files
Nikhil Pavan Kalyan Feb 23, 2011 4:07 AM (in response to electroteque1)Hi,
I do not think the inspect-fragments dump is entirely correct. I have fragmented the same file (the demo file from FMS) with default fragmentation values and was able to playback. I am copying here the first few lines from the inspect fragments dump:
fragment: 1, 74912
afra:
long ids: true
long offsets: true
entries:
time = 0, offset = 16511
time = 3003, offset = 275611
global entries:
bootstrap:
version: 1
is update: false
is live: false
movie id:
timescale: 1000
current media time: 6006
smpte timecode offset: 0
servers:
qualities:
segments:
segment run table:
is update: false
qualities:
entries:
segment = 1, fragments = 1
fragments:
fragment run table:
is update: false
qualities:
entries:
fragment = 1, timestamp = 0, duration = 6000
fragment: 2, 600951
afra:
long ids: true
long offsets: true
entries:
time = 6006, offset = 8367
global entries:
bootstrap:
version: 2
is update: false
is live: false
movie id:
timescale: 1000
current media time: 9009
servers:
qualities:
segments:
segment run table:
is update: false
qualities:
entries:
segment = 1, fragments = 2
fragments:
fragment run table:
is update: false
qualities:
entries:
fragment = 2, timestamp = 6006, duration = 3000
fragment: 3, 833788
afra:
long ids: true
long offsets: true
entries:
time = 9009, offset = 8419
global entries:
bootstrap:
version: 2
is update: false
is live: false
movie id:
timescale: 1000
current media time: 12012
servers:
qualities:
segments:
segment run table:
is update: false
qualities:
entries:
segment = 1, fragments = 3
If you compare this part with that of what you have, you can observe that under fragment 2, you have the entry segment= 1 and fragments = 3 which is wrong. (my output has segment=1 and fragments =2 , which is correct).
So, can you confirm whats the command you used for packaging ? Or probably, try with the default packaging and see if you still get the mismatched entries in inspect fragments.
What build of FMS/File packager are you using ? Probably if thats old, you may want to switch to the most recent release.
Thank you !
6. Re: Getting 503 errors for f4f httpstreaming files
electroteque1 Feb 23, 2011 4:15 AM (in response to Nikhil Pavan Kalyan)I tried a various amount of things after researching constantly, tried f4fpackager --input-file= , and with framerate and fragement duration flags and still didn't help. The problem was a bad apache location configuration, see above. It should be returning 404 errors and logging the problem instead of returning 503 errors and not logging at all. Can this be fixed in another version ?
Im using the standalone f4fpackager btw and FMS 4 Developer version, and a standalone apache.
My test stream works now.
7. Re: Getting 503 errors for f4f httpstreaming files
Nikhil Pavan Kalyan Feb 23, 2011 5:01 AM (in response to electroteque1)Good to know that you have the issue resolved !
I am little not sure about getting the wrong response code (503 instead of 404) because the f4f module does nothing but to redirect the status (error or otherwise) to apache which makes the response. Almost all the times when the configuration was wrong and when we had path related mismatches, 404 is what is recieved. Do post your observations as you try more and we can nail down the real issue
But, can you please send me the exact f4fpackager command that you used while packaging for which you got the inspect fragments that you attached? I would like to reproduce and get the same inspect fragments ouput (with errors) and see what's causing that.
Thank you !
8. Re: Getting 503 errors for f4f httpstreaming files
nick.doyle Nov 27, 2011 5:08 PM (in response to electroteque1)electroteque I'm having the same issue
Can you tell me how you changed your configuration to work around it?
I'm also wondering why the player is even asking for non-existent fragments ... I guess I need to get code to read the f4x for me ....
9. Re: Getting 503 errors for f4f httpstreaming files
electroteque1 Nov 27, 2011 11:36 PM (in response to nick.doyle)Just the wrong path set when referencing the file because it was already included in the apache config. The other issues now is switching bitrates and the audio glitching but there is a bug report for this.
