I am using Robohelp 9 on a Windows 7 machine for a Robpohelp HTML project.
To see if I could reproduce it, I tried this with two different projects, my original one and a new one, in a different folder, that I used for testing.
When I select "Microsoft HTML Help" as the layout and generate it, the message says that "Microsoft HTML Help was built succesfully" but when I click the "View Result" button nothing happens.
When looking at the folder where it should have been created, the folder is empty.
PB
Are you using Norton AV by any chance? I had a similar experience because Norton deemed some file unsafe. I'll try to locate the details if this could be the reason.
No, I am not. I am not using an anti-virus program.
Also, I can generate help files in other layout, just not chm files.
The problem I had only affected CHMs because the AV blew away the viewer.
Brave soul not using AV software.
I assume you have checked and rechecked your paths and you are generating to a local folder so I'll have to leave it to someone who works more with CHMs than I do.
Well, I am using Windows Defender
Hi there
When you double-click the single source layout for Microsoft HTML Help, please copy the contents of the first field and paste them into a forum post for us to review.
Cheers... Rick
The first field is
"Output Folder and Filename" and the content is:
C:\temp\RH9\TEST\!SSL!\Microsoft_HTML_Help\TEST.chm
all other options have prefix "Default" and "Optimize CHM File Size" is checked
BTW, this is the Output View Report:
Starting compilation...
HTMLHELP preprocessor 9.0.0.228
Compiling C:\temp\RH9\TEST\!SSL!\Microsoft_HTML_Help\!chm_tmp_folder_0\TEST.chm ...
Preparing to create HTMLHELP...
Clearing output folder...
Preparing files for HTML Help...
Copying files...
Updating files...
Finished preparing in 0 sec(s)
Initializing compiler...
Generating HTMLHELP (9.0.0.228)...
Updating topics...
Updating First_Topic.htm...
Updating New_Topic2.htm...
Warning: The size of stop file has to be limited in 512 bytes.
C:\temp\RH9\TEST\!SSL!\Microsoft_HTML_Help\!chm_tmp_folder_0\TEST.hhp
HHC5010: Error:
Cannot open "c:\temp\RH9\TEST\!SSL!\Microsoft_HTML_Help\TEST.chm". Compilation stopped.
Finished compiling HTMLHELP in 1 sec(s)
Compilation complete.
