I am trying to import a WinHelp project created with RH 8 for Word into RH 8 HTML. I have noticed two major things:
1. The first topic is preceded by the names of many fonts. At the end of these set of fonts, my topic appears. I am attaching a partial view of these fonts below:
Arial;Courier New;Symbol;Helvetica;Courier;Tms Rmn;Helv;New York;System;Wingdings;MS
Mincho ;Batang ;SimSun ;PMingLiU ;MS Gothic ;Dotum ;SimHei ;MingLiU ;Mincho ;Gulim
;Century;Angsana New;Cordia New;Mangal;Latha;Sylfaen;Vrinda;Raavi;Shruti;Sendnya;Gautami;Tunga;Estrangelo
Edessa;Cambria Math;Arial Unicode MS;Cambria;Calibri;Tahoma;CG Times ;Univers ;Times;Verdana;CommonBullets;Webdings;WP
MathA;Adobe Caslon Pro Bold;Adobe Caslon Pro;Adobe Fangsong Std R;@Adobe Fangsong
Std R;Adobe Fan Heiti Std B;@Adobe Fan Heiti Std B;Adobe Gothic Std B;@Adobe Gothic
Std B;Adobe Heiti Std R;@Adobe Heiti Std R;Adobe Kaiti Std R;@Adobe Kaiti Std R;Adobe
Garamond Pro Bold;Adobe Garamond Pro;Birch Std;Blackoak Std;Brush Script Std;Chaparral
Pro;Charlemagne Std;Cooper Std Black;Giddyup Std;Hobo Std;Kozuka Gothic Pr6N B;@Kozuka
Gothic Pr6N B;Kozuka Gothic Pr6N EL;@Kozuka Gothic Pr6N EL;
2. All Topics are imported as far as I could tell at a glance, but all the fonts have changed. I used styles based on the Normal_RWH.dot template that has been modified.
Anyone can tell me how to recover my fonts besides doing so manually?
Esperanza
It sounds like the first problem is related to Snippet 56.
http://www.grainge.org/pages/snippets/snippets.htm
My guess is you just delete the unwanted text.
To correct the styles you may be lucky and just have to go into the Style Editor and change the font for each style. If not you will need to look at the HTML and you will likely find an inline style sheet in the topics and maybe even inline styling. Sorting that out will depend on your knowledge of HTML.
Snippet 104 may also help you.
Post back if more help needed when you have worked through that.
