      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
Nothing there after generating Microsoft HTML Help
Guest
Feb 23, 2011 Feb 23, 2011
I am using Robohelp 9 on a Windows 7 machine  for a Robpohelp HTML project.
To see if I could reproduce it, I tried this with two different projects, my original one and a new one, in a different folder, that I used for testing.
When I select "Microsoft HTML Help" as the layout and generate it, the message says that "Microsoft HTML Help was built succesfully" but when I click the "View Result" button nothing happens.
When looking at the folder where it should have been created, the folder is empty.
PB
841
Are you using Norton AV by any chance? I had a similar experience because Norton deemed some file unsafe. I'll try to locate the details if this could be the reason.
@petergrainge
Guest
No, I am not. I am not using an anti-virus program.
Also, I can generate help files in other layout, just not chm files.
The problem I had only affected CHMs because the AV blew away the viewer.
Brave soul not using AV software.
I assume you have checked and rechecked your paths and you are generating to a local folder so I'll have to leave it to someone who works more with CHMs than I do.
@petergrainge
Guest
Feb 24, 2011 Feb 24, 2011
Well, I am using Windows Defender
Hi there
When you double-click the single source layout for Microsoft HTML Help, please copy the contents of the first field and paste them into a forum post for us to review.
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7, 8 or 9 within the day!
Adobe Certified RoboHelp HTML Training
SorcerStone Blog
RoboHelp eBooks
Guest
The first field is
"Output Folder and Filename" and the content is:
C:\temp\RH9\TEST\!SSL!\Microsoft_HTML_Help\TEST.chm
all other options have prefix "Default" and "Optimize CHM File Size" is checked
Guest
Feb 28, 2011 Feb 28, 2011
BTW, this is the Output View Report:
Starting compilation...
HTMLHELP preprocessor 9.0.0.228
Compiling C:\temp\RH9\TEST\!SSL!\Microsoft_HTML_Help\!chm_tmp_folder_0\TEST.chm ...
Preparing to create HTMLHELP...
Clearing output folder...
Preparing files for HTML Help...
Copying files...
Updating files...
Finished preparing in 0 sec(s)
Initializing compiler...
Generating HTMLHELP (9.0.0.228)...
Updating topics...
Updating First_Topic.htm...
Updating New_Topic2.htm...
Warning: The size of stop file has to be limited in 512 bytes.
C:\temp\RH9\TEST\!SSL!\Microsoft_HTML_Help\!chm_tmp_folder_0\TEST.hhp
HHC5010: Error:
Cannot open "c:\temp\RH9\TEST\!SSL!\Microsoft_HTML_Help\TEST.chm". Compilation stopped.
Finished compiling HTMLHELP in 1 sec(s)
Compilation complete.
RoboHelp Documentation
Download Adobe RoboHelp
