I have tried everything... I have downloaded, installed, uninstalled, and reinstalled again, and flash player is not showing in my programs. I can only get it in files, and It does not work. I am not able to see anything that requires Flash Player 10.2. I have check to ensure I am using 32 bit, I am at a complete loss. Please help! Thanks
What is your operating system & version?
What is your web browser & version?
What means "not able" - do you get any errors, or what exactly are your symptoms?
I have Windows 7, Internet Explorer. The download and Install say complete, but I am not able to find it in my programs. When i go to video that requires flash player it does not show that I have it. I am not sure what I am doing wrong. I am not getting any error messages, but it appears as if it isn't installed even though it states install complete.
The standard Flash Player is a browser add-on, not a standalone program, so you will not find it in your Porgrams folder.
On Internet Explorer, Tools | Add-ons, can you see Shockwave Flash object, and is it enabled?
Also, is your Windows 7 32-bit or 64-bit? If 64-bit, do you use the 32-bit version of Internet Explorer?
it is not showing as a browser add on either. When I followed your instructions Shockwave Flash object is not listed under the tools. It is a 64 bit,
Can you check if you have the "kill-bit" for Flash Player set in your registry: http://forums.adobe.com/message/3432049#3432049 ?
If yes, don't fix it manually - I can give you an easier way to remove it.
Still, do you use the 32-bit or 64-bit version of Internet Explorer?
