s.......,
Near the end of the output file whskin_tbars.htm you should
see something like this:
addButton("toc",BTN_TEXT,"Contents","","","","",0,0,"","","","","","");
addButton("idx",BTN_TEXT,"Index","","","","",0,0,"","","","","","");
addButton("fts",BTN_TEXT,"Search","","","","",0,0,"","","","","","");
addButton("searchform",BTN_TEXT,"","","","","",0,0,"","","","","","");
addButton("custom7279", . . . . .
and near the top of whstart.js you should see, depending on
their order,
var gsToolbarOrder =
"custom7279|toc|idx|fts|blankblock|searchform";
If "searchform" is not there, you have a problem in
generating the skin. If it is there, you have a display problem.
If it's not there, I'd suspect the WebHelp "Single Source
Layout." Recheck the layout to be sure you are calling for the
search form in the toolbar. If you are, delete the layout and
create a new one. Another way is to delete its .ssl file in the RH
project folder (project must be closed), reopen RH and re-create
the layout.
My guess is that searchform is there, but something is
forcing it down past the bottom of the toolbar.
Where and how are you changing the height of the toolbar?
Harvey
