I have a project where about a thousand topics were moved into a different help file. This results in a ton of empty index entries in my current project. I'm creating a brand new index and have set the build layout to use the new one. Is there a way to delete the old index from within RH?
I see a delete item on the right-click shortcut menu for the index I want to delete. But it's grayed out, presumeably because it's the default index. So I think I need to set the new index as the default, right? Where would I do that?
RH 7 (with latest patch)
Windows 7 64-bit
If you right click on your new index there is an option to make that the default. Then the delete option should be available on the old index.
The RoboColum(n) | @robocolumn | Colum McAndrew |
I think that option only came in RoboHelp 8.
Thanks guys. But, I don't see any "Set as Default" option when right-clicking. I vaguely remember fixing something like this in the past, but not sure. I tried manually removing the HHK file from the software, but the deleted index still technically remains inside the project manager albeit with a red X. Is there a registry setting or something that I can use to remove it? It's not a huge deal if I have to keep it around, just bugs me that I have to.
Couldn't you:
Then, just delete new_index.hhk.
Good luck,
Leon
Yes. I could do that. I thought of doing that right after I posted the above. Just wondering if there was a different way. Maybe not. Thanks for the responses.
Peter Grainge and Leon are both correct. With RH 7, you cannot set up a default index. You will have to manually do it as suggested by Leon.
