15 Replies Latest reply: Aug 27, 2011 7:58 AM by Alan Slingsby RSS
    InDesign CS5 crashes copying a picture box
    confused_again Community Member
      In a multipage document, if I alt-click-and-drag to copy a picture box from one page down across the "artboard divide" to another page (eg from page 1 to page 3), InDesign crashes. I have tried this even with a completely empty file and just a pic box with a red fill (so hardly any data). This never used to happen... Has anyone experienced similar?
        • 2. Re: InDesign CS5 crashes copying a picture box
          Thanks. I had considerd resetting porefs etc, but the issue is that as a group we have just upgraded to CS5 and this is being seen on more than one machine, so I'm inclined to think it isn't just my machine playing up (ie it's not something that prefs would fix). We are also hooked into WoodWing, so that may be having an effect, but I'd be slightly surprised if WoodWing was affecting this particular operation....
          • 3. Re: InDesign CS5 crashes copying a picture box
            P Spier CommunityMVP
            It's possible something in the configuration is corrupting the prefs, or the document. It would be worthwhile to try replacing the prefs on one machine and see if the problem goes away, even temporarily.
            • 4. Re: InDesign CS5 crashes copying a picture box
              I have since tried the prefs - trashed saved data and prefs files - relaunched InDesign. Problem still remains.
              • 5. Re: InDesign CS5 crashes copying a picture box
                Next step would be to disable all third party plugins and test, then add in again one at a time until it doesn't work (presuming it works with them disabled).
                • 6. Re: InDesign CS5 crashes copying a picture box
                  Alan Slingsby Community Member
                  This happening to me too using Lion 7.1 and iD CS 5.5
                  Thought it mighht be a server issue, but it is not. Happens when alt-dragging on same page, not across pages (never get that far)
                  Don't think it's the image files. Can cut/copy and paste without problems.
                  • 8. Re: InDesign CS5 crashes copying a picture box
                    Hi John
                    See attached
                    Date/Time:       2011-08-27 12:29:44 +0100
                    OS Version:      10.7.1 (Build 11B26)
                    Architecture:    x86_64
                    Report Version:  8
                    Command:         InDesign
                    Path:            /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/MacOS/Adobe InDesign CS5.5
                    Version:         7.5.1.304 (7510)
                    Parent:          launchd 291
                    PID:             1926
                    Event:           hang
                    Duration:        1.19s
                    Steps:           13 (100ms sampling interval)
                    Pageins:         0
                    Pageouts:        0
                    Process:         Adobe InDesign CS5.5 1926
                    Architecture:    i386
                    UID:             503
                      Thread 0x14846
                      User stack:
                        13 start + 54 (in Adobe InDesign CS5.5) 0x27c6
                          13 main + 187 (in Adobe InDesign CS5.5) 0x28ab
                            13 GetPlugIn + 14282 (in AppFramework) 0xe38800a
                              13 ??? (in AppFramework) 0xe362aff
                                13 SendEventToEventTarget + 76 (in HIToolbox) 0x96cc6ac9
                                  13 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCall Rec + 482 (in HIToolbox) 0x96cb1ca8
                                    13 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 2813 (in HIToolbox) 0x96cb2ce6
                                      13 _ZL29ToolboxEventDispatcherHandlerP25OpaqueEventHandlerCallRefP14OpaqueEventRefPv + 1915 (in HIToolbox) 0x96cc7249
                                            13 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1602 (in HIToolbox) 0x96cb282b
                                              13 _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef, OpaqueEventRef, void, long ()(OpaqueEventHandlerCallRef, OpaqueEventRef, void*)) + 36 (in HIToolbox) 0x96e36e54
                                                13 GetPlugIn + 691834 (in Application UI) 0xfcf7d7a
                                                  13 GetPlugIn + 288524 (in Application UI) 0xfc9560c
                                                    13 GetPlugIn + 298102 (in Application UI) 0xfc97b76
                                                      13 CEventDispatcher::DispatchEvent(IEvent*, IEvent::SystemHandledState) + 24 (in PublicLib.dylib) 0x12b7218
                                                        13 CEventDispatcher::DispatchToEventHandlers(IEvent*) + 222 (in PublicLib.dylib) 0x12b775e
                                                          13 CDefaultEH::LButtonDn(IEvent*) + 48 (in WidgetBinLib.dylib) 0x29bf0f0
                                                            13 GetPlugIn + 704196 (in Application UI) 0xfcfadc4
                                                              13 PanelEventHandler::LButtonDn(IEvent*) + 116 (in WidgetBinLib.dylib) 0x292d114
        13 ??? (in Layout UI) 0xed96fb2
        13 ??? (in Layout UI) 0xed96a02
        13 ??? (in Layout UI) 0xeda44b6
        13 GetPlugIn + 485266 (in Layout UI) 0xee7fb32
        13 GetPlugIn + 247042 (in Application UI) 0xfc8b402
        13 CmdUtils::EndCommandSequence(IAbortableCmdSeq*) + 51 (in PublicLib.dylib) 0x1297ae3
        13 ??? (in AppFramework) 0xe379351
        13 ??? (in AppFramework) 0xe373931
        13 ??? (in AppFramework) 0xe373442
        13 GetPlugIn + 977491 (in AppFramework) 0xe473293
        13 GetPlugIn + 976922 (in AppFramework) 0xe47305a
        13 GetPlugIn + 159428 (in Links) 0x147243f4
        13 CSubject::ModelChange(IDType const&, void, LazyNotificationData) + 131 (in PublicLib.dylib) 0x1382a63
        13 GetPlugIn + 43855 (in AppFramework) 0xe38f38f
        13 GetPlugIn + 47161 (in AppFramework) 0xe390079
        13 GetPlugIn + 45687 (in AppFramework) 0xe38fab7
        13 GetPlugIn + 285701 (in Package and Preflight) 0xf65f035
        13 GetPlugIn + 271597 (in Package and Preflight) 0xf65b91d
        13 ??? (in Package and Preflight) 0xf6063f9
        13 ??? (in Package and Preflight) 0xf5fe977
        13 ??? (in Package and Preflight) 0xf602b90
        13 ??? (in Package and Preflight) 0xf602c30
        10 ??? (in Package and Preflight) 0xf602c30
        2 ??? (in Package and Preflight) 0xf602969
        1 ??? (in Package and Preflight) 0xf602a10
        1 ??? (in Package and Preflight) 0xf6028c3
        1 ??? (in Package and Preflight) 0xf6028ab
        1 ??? (in Package and Preflight) 0xf602982
        1 ??? (in Package and Preflight) 0xf6028c7
        1 ??? (in Package and Preflight) 0xf6028cd
        1 ??? (in Package and Preflight) 0xf6028ca
        1 ??? (in Package and Preflight) 0xf60296d
        2 ??? (in Package and Preflight) 0xf602c1c
        1 ??? (in Package and Preflight) 0xf6029b6
                    • 9. Re: InDesign CS5 crashes copying a picture box
                      John Hawkinson CommunityMVP
                      Oh my. That's really too long for the forum, I'm sorry I wasn't more clear when I  said "the thread0" section -- that's just a few lines near the top. Posts of that length really make the forum un-navigable. Generally we ask that you paste the file to pastebin.com and include a link.
                      Could you please edit your post to remove that? It makes it pretty tough for anyone to benefit from this thread and seperate the what from the chaff.
                      Thanks!!
                      • 10. Re: InDesign CS5 crashes copying a picture box
                        OK, well, formatting aside, See below for the relevant section.
                        Note that this is not in fact a crash report, but rather a "hang" report. Presumsbly, therefore, you're not seeing actual crashes where the program exits?
                        In any case, the source is clear enough. These are read backwards, with the top of the stack at the bottom, and you can see that it is noodling around in the Package and Preflight module. So, it's related to preflight and one of your preflight checks. So try turning off preflight.
                        I have a quite serious interest in trying to get these preflight problems fixed. Can you reduce this to a small reproducible sample? Can you
                        then email those files to me? I would very much appreciate it.
                        Anyhow, the pertinent part of the report:
                        PID:              1926
                        Event:           hang
                        Duration:        1.19s
                        Thread 0x14846
                        User stack:
                        13 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTar getRefP14HandlerCallRec + 482 (in HIToolbox) 0x96cb1ca8
                        13 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14Hand lerCallRec + 2813 (in HIToolbox) 0x96cb2ce6
                        13 _ZL29ToolboxEventDispatcherHandlerP25OpaqueEventHandlerCallRefP14Opaq ueEventRefPv + 1915 (in HIToolbox) 0x96cc7249
                        13 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14Hand lerCallRec + 1602 (in HIToolbox) 0x96cb282b
                        • 11. Re: InDesign CS5 crashes copying a picture box
                          BobLevine CommunityMVP
                          I wasn't sure where to edit this so I erred on the side of leaving a bit too much. I'm sure you got it via email anyway.
                          Bob
                          • 12. Re: InDesign CS5 crashes copying a picture box
                            Hi John
                            Have deleted most of the over-long post. Didn't realise it would end up in the forum.
                            I was using a custom pre-flight profile (attached) with flight checking on continuously which I suspect may be the problem.
                            The files I was working were very large (1600mm x 800mm display panels, six in a document, with jpeg sizes and resolutions to match.
                            Profile intended for magazines was clearly not appropriate and I forgot it was on. It did not seem to slow things down much.
                            I have now turned it off and will see if problem continues.
                            • 13. Re: InDesign CS5 crashes copying a picture box
                              Whoops...looks like somehow between your edit and Bob's edit (thanks, Bob!),
                              the post got longer again. Anyone want to try again?
                              In any case, I've sent a private note to Alan about getting his files.
                              • 14. Re: InDesign CS5 crashes copying a picture box
                                Alan,
                                Everything winds up on the web page. Please delete your contact info when replying by email. I've done it for you this time.
                                • 15. Re: InDesign CS5 crashes copying a picture box
                                  Have worked on document that was causing problem with flightchecking switched off and with it on but using only the default "basic" setting.
                                  Cannot immediately replicate hangs in either of these two modes.
