The value "115,223.39" cannot be converted to a number
Participant ,
Jul 07, 2006 Jul 07, 2006
I have this value "115,223.39" in my database when it tries to pull this data i get this message.
The value "115,223.39" cannot be converted to a number....Any help on this
Advanced techniques
618
Participant , Jul 07, 2006 Jul 07, 2006
Thanks 4 the help guys but all i needed to do was add that replace statement inside my loop...It was not being converted beacause it was outside the loop...dang.....thanks 4 the help...thats the correct code snippet.....
It's not a number, it is a string, it has a comma in it.
You will need to do something to remove the comma if you want it to be a
number. A large hammer way to do this is with replace.
#replace('115,223.60',',','','ALL')#
Boy that is a bit confusing isn't it. Make sure you get all the quotes
and commas matched up correctly.
> get this message.
> <cfset res.endingar = Replace(res.endingar, ",", "", "all")>
> <cfchart format="jpg" chartheight="400" chartwidth="800">
> <cfchartseries type="line" colorlist="008800,00cc00, 000088, 0000cc">
> <cfloop query="res">
> <cfchartdata item="#res.themonth#" value="#Int(res.endingar)#">
> </cfloop>
> </cfchartseries>
> </cfchart>
> </cfoutput>
Ok, actually looking at your code you are replacing comma's. You may
need to add a val() function around that to force the conversion from
string to number.
>> this
>> 0000cc">
>> </cfloop>
>> </cfchartseries>
>> </cfchart>
>> </cfoutput>
Guest
Ignore.
Participant ,
<cfset res.charges = Val(Round(Replace(res.charges, ",", "", "all")))>
I still get the same error...that number is just a value it pulls from the sql server.....im lost
Try putting the val before the round, since the round function would
also be expecting a number.
Are there any null values in the records returned by the query. These
can cause this kind of problem since an "" [empty string] is not a
number. Putting a val() around that will return a zero '0' for
null|empty string values in the recordset.
Advisor ,
"res" is a query. So that approach will not work unless the query contains exactly one row.
The BEST thing to do is to fix the data in your original query, like so:
<CFQUERY name="res" ... ...>
SELECT
themonth,
Replace (endingar, ",", "") AS endingar
</CFQUERY>
The above syntax works in many RDBMS. Tell us which RDMBS you are using if it doesn't work for you.
Participant ,
Actually since it is in a query loop it will work just fine to output
all the records in the set.
Test code that can be run if you have the CF sample databases installed.
<cfquery datasource="cfartgallery" name="test">
SELECT ARTISTID
FROM ARTISTS
</cfquery>
<cfoutput>
<cfloop query="test">
#test.artistid#<br/>
</cfloop>
</cfoutput>
> exactly one row.
> SELECT
> themonth,
> </CFQUERY>
Documentation
