Hi All,
I just install FB burrito and the plugin for eclipse.
But I cannot lauch it correctly.
When I double click the FB icon, it just show the splash screen and a input serial number window.
And the IDE window pops up and disappeared very soon.
I cannot find any error message in the Windows event log or amt3.log.
Is there anybody can help with this?
Thanks a lot.
Can you provide us the following details:
1) version of Flash Builder Burrito
2) Version of eclipse
3) Launch the eclipse (on which you installed FB) and attach the log file from Eclipse -> About Eclipse ->Installation Details ->Configuration ->Error Log. Also check if the 'Flash' perspective opens.
Balaji
1) I am using flashbuilder_burrito_287807
2) Eclipse SDK Version: 3.6.1 Build id: M20100909-0800
3) It is strange that I can use the perspective to switch Java eclipse to flash eclipse! Thank you!
here is the error log:
!SESSION 2011-02-24 10:27:04.842 ----------------------------------------------- eclipse.buildId=M20100909-0800 java.version=1.6.0_24 java.vendor=Sun Microsystems Inc. BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US Command-line arguments: -os win32 -ws win32 -arch x86 !ENTRY org.eclipse.equinox.preferences 4 4 2011-02-24 10:29:02.506 !MESSAGE Exception loading preferences from: . !STACK 0 org.osgi.service.prefs.BackingStoreException: Unable to determine provisioning agent from location: file:\2fD:\2feclipse\2fconfiguration\2f..\2fp2\2f at org.eclipse.equinox.internal.p2.engine.ProfilePreferences.getAgent(ProfilePreferences.java:159) at org.eclipse.equinox.internal.p2.engine.ProfilePreferences.load(ProfilePreferences.java:240) at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:307) at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences.java:543) at org.eclipse.core.internal.preferences.EclipsePreferences.node(EclipsePreferences.java:669) at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences.java:549) at org.eclipse.core.internal.preferences.EclipsePreferences.node(EclipsePreferences.java:669) at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences.java:549) at org.eclipse.core.internal.preferences.EclipsePreferences.node(EclipsePreferences.java:669) at org.eclipse.core.internal.preferences.RootPreferences.getNode(RootPreferences.java:106) at org.eclipse.core.internal.preferences.RootPreferences.node(RootPreferences.java:85) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.getPreferences(AbstractRepositoryManager.java:499) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.remember(AbstractRepositoryManager.java:857) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.stop(AbstractRepositoryManager.java:1052) at org.eclipse.equinox.internal.p2.core.ProvisioningAgent.unregisterService(ProvisioningAgent.java:121) at org.eclipse.equinox.internal.p2.core.ProvisioningAgent.removedService(ProvisioningAgent.java:182) at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:922) at org.osgi.util.tracker.AbstractTracked.untrack(AbstractTracked.java:351) at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:865) at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:104) at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:933) at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227) at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:149) at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:756) at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:711) at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:225) at org.eclipse.equinox.internal.ds.InstanceProcess.disposeInstances(InstanceProcess.java:355) at org.eclipse.equinox.internal.ds.InstanceProcess.disposeInstances(InstanceProcess.java:305) at org.eclipse.equinox.internal.ds.Resolver.disposeComponentConfigs(Resolver.java:685) at org.eclipse.equinox.internal.ds.Resolver.disableComponents(Resolver.java:661) at org.eclipse.equinox.internal.ds.SCRManager.stoppingBundle(SCRManager.java:553) at org.eclipse.equinox.internal.ds.SCRManager.bundleChanged(SCRManager.java:232) at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:919) at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227) at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:149) at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEventPrivileged(Framework.java:1349) at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1300) at org.eclipse.osgi.framework.internal.core.BundleHost.stopWorker(BundleHost.java:497) at org.eclipse.osgi.framework.internal.core.AbstractBundle.suspend(AbstractBundle.java:550) at org.eclipse.osgi.framework.internal.core.Framework.suspendBundle(Framework.java:1097) at org.eclipse.osgi.framework.internal.core.StartLevelManager.decFWSL(StartLevelManager.java:597) at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:257) at org.eclipse.osgi.framework.internal.core.StartLevelManager.shutdown(StartLevelManager.java:215) at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.suspend(InternalSystemBundle.java:266) at org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework.java:690) at org.eclipse.osgi.framework.internal.core.Framework.close(Framework.java:588) at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(EclipseStarter.java:415) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:198) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574) at org.eclipse.equinox.launcher.Main.run(Main.java:1407) !SESSION 2011-02-24 10:38:08.356 ----------------------------------------------- eclipse.buildId=M20100909-0800 java.version=1.6.0_24 java.vendor=Sun Microsystems Inc. BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US Command-line arguments: -os win32 -ws win32 -arch x86 !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 10:40:58.066 !MESSAGE Connection to http://download.eclipse.org/eclipse/updates/3.6/p2.index failed on No route to host: connect. Retry attempt 0 started !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576) at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98) at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342) at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:115) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:100) at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$2.runModal(PreloadingRepositoryHandler.java:82) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !ENTRY org.eclipse.core.net 1 0 2011-02-24 10:41:11.270 !MESSAGE System property http.proxyHost is not set but should be camaproxy.am.thmulti.com. !ENTRY org.eclipse.core.net 1 0 2011-02-24 10:41:11.286 !MESSAGE System property http.proxyPort is not set but should be 80. !ENTRY org.eclipse.core.net 1 0 2011-02-24 10:41:11.317 !MESSAGE System property https.proxyHost is not set but should be camaproxy.am.thmulti.com. !ENTRY org.eclipse.core.net 1 0 2011-02-24 10:41:11.332 !MESSAGE System property https.proxyPort is not set but should be 80. !SESSION 2011-02-24 15:46:37.115 ----------------------------------------------- eclipse.buildId=M20100909-0800 java.version=1.6.0_24 java.vendor=Sun Microsystems Inc. BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US Command-line arguments: -os win32 -ws win32 -arch x86 !ENTRY org.eclipse.ui 4 4 2011-02-24 15:48:17.148 !MESSAGE Unable to find view with id: com.adobe.flashbuilder.analytics.ui.SiteCatalystView, when creating perspective com.adobe.flexbuilder.editors.mxml.ui.perspectives.development !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 15:53:51.319 !MESSAGE Connection to http://download.eclipse.org/eclipse/updates/3.6/p2.index failed on No route to host: connect. Retry attempt 0 started !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576) at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98) at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342) at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:115) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:100) at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$2.runModal(PreloadingRepositoryHandler.java:82) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !ENTRY org.eclipse.equinox.p2.core 4 0 2011-02-24 15:55:57.338 !MESSAGE Provisioning exception !STACK 1 org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://download.eclipse.org/eclipse/updates/3.6/content.xml. at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:189) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:66) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:88) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:746) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:651) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:115) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:100) at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$2.runModal(PreloadingRepositoryHandler.java:82) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) Caused by: java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:227) at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69) ... 1 more !SUBENTRY 1 org.eclipse.equinox.p2.repository 4 1002 2011-02-24 15:55:57.338 !MESSAGE Unable to read repository at http://download.eclipse.org/eclipse/updates/3.6/content.xml. !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:227) at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 15:56:18.221 !MESSAGE Connection to http://download.eclipse.org/eclipse/updates/3.6/p2.index failed on No route to host: connect. Retry attempt 0 started !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576) at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98) at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342) at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92) at org.eclipse.equinox.p2.engine.ProvisioningContext.loadMetadataRepository(ProvisioningContext.java:211) at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedMetadataRepositories(ProvisioningContext.java:194) at org.eclipse.equinox.p2.engine.ProvisioningContext.getMetadata(ProvisioningContext.java:275) at org.eclipse.equinox.internal.p2.director.SimplePlanner.gatherAvailableInstallableUnits(SimplePlanner.java:322) at org.eclipse.equinox.internal.p2.director.SimplePlanner.getSolutionFor(SimplePlanner.java:382) at org.eclipse.equinox.internal.p2.director.SimplePlanner.getProvisioningPlan(SimplePlanner.java:440) at org.eclipse.equinox.internal.p2.operations.PlannerResolutionJob.runModal(PlannerResolutionJob.java:76) at org.eclipse.equinox.p2.operations.ProfileChangeOperation.resolveModal(ProfileChangeOperation.java:115) at org.eclipse.equinox.internal.p2.ui.dialogs.ProvisioningOperationWizard$1.run(ProvisioningOperationWizard.java:207) at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121) !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 15:57:00.190 !MESSAGE Connection to http://download.eclipse.org/releases/helios/p2.index failed on No route to host: connect. Retry attempt 0 started !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576) at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98) at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342) at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:115) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:100) at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$2.runModal(PreloadingRepositoryHandler.java:82) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !ENTRY org.eclipse.equinox.p2.core 4 0 2011-02-24 15:58:45.197 !MESSAGE Provisioning exception !STACK 1 org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://download.eclipse.org/releases/helios/content.xml. at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:189) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:66) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:88) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:746) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:651) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:115) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:100) at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$2.runModal(PreloadingRepositoryHandler.java:82) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) Caused by: java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:227) at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69) ... 1 more !SUBENTRY 1 org.eclipse.equinox.p2.repository 4 1002 2011-02-24 15:58:45.197 !MESSAGE Unable to read repository at http://download.eclipse.org/releases/helios/content.xml. !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:227) at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 15:59:27.072 !MESSAGE Connection to http://download.eclipse.org/releases/helios/p2.index failed on No route to host: connect. Retry attempt 0 started !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576) at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98) at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342) at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92) at org.eclipse.equinox.p2.engine.ProvisioningContext.loadMetadataRepository(ProvisioningContext.java:211) at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedMetadataRepositories(ProvisioningContext.java:194) at org.eclipse.equinox.p2.engine.ProvisioningContext.getMetadata(ProvisioningContext.java:275) at org.eclipse.equinox.internal.p2.director.SimplePlanner.gatherAvailableInstallableUnits(SimplePlanner.java:322) at org.eclipse.equinox.internal.p2.director.SimplePlanner.getSolutionFor(SimplePlanner.java:382) at org.eclipse.equinox.internal.p2.director.SimplePlanner.getProvisioningPlan(SimplePlanner.java:440) at org.eclipse.equinox.internal.p2.operations.PlannerResolutionJob.runModal(PlannerResolutionJob.java:76) at org.eclipse.equinox.p2.operations.ProfileChangeOperation.resolveModal(ProfileChangeOperation.java:115) at org.eclipse.equinox.internal.p2.ui.dialogs.ProvisioningOperationWizard$1.run(ProvisioningOperationWizard.java:207) at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121) !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 16:01:15.182 !MESSAGE Connection to http://download.eclipse.org/eclipse/updates/3.6/p2.index failed on No route to host: connect. Retry attempt 0 started !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576) at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98) at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342) at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639) at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:99) at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:95) at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedArtifactRepositories(ProvisioningContext.java:160) at org.eclipse.equinox.p2.engine.ProvisioningContext.getArtifactRepositories(ProvisioningContext.java:143) at org.eclipse.equinox.internal.p2.engine.phases.Sizing.completePhase(Sizing.java:91) at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:216) at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:84) at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:44) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:73) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44) at org.eclipse.equinox.internal.p2.ui.ProvUI.getSize(ProvUI.java:253) at org.eclipse.equinox.internal.p2.ui.dialogs.SizeComputingWizardPage$1.run(SizeComputingWizardPage.java:63) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 16:03:21.990 !MESSAGE Connection to http://download.eclipse.org/releases/helios/p2.index failed on No route to host: connect. Retry attempt 0 started !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576) at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98) at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342) at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639) at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:99) at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:95) at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedArtifactRepositories(ProvisioningContext.java:160) at org.eclipse.equinox.p2.engine.ProvisioningContext.getArtifactRepositories(ProvisioningContext.java:143) at org.eclipse.equinox.internal.p2.engine.phases.Sizing.completePhase(Sizing.java:91) at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:216) at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:84) at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:44) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:73) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44) at org.eclipse.equinox.internal.p2.ui.ProvUI.getSize(ProvUI.java:253) at org.eclipse.equinox.internal.p2.ui.dialogs.SizeComputingWizardPage$1.run(SizeComputingWizardPage.java:63) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 16:14:27.966 !MESSAGE Connection to http://download.eclipse.org/eclipse/updates/3.6/p2.index failed on No route to host: connect. Retry attempt 0 started !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576) at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98) at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342) at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639) at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:99) at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:95) at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedArtifactRepositories(ProvisioningContext.java:160) at org.eclipse.equinox.p2.engine.ProvisioningContext.getArtifactRepositories(ProvisioningContext.java:143) at org.eclipse.equinox.internal.p2.engine.DownloadManager.start(DownloadManager.java:72) at org.eclipse.equinox.internal.p2.engine.phases.Collect.completePhase(Collect.java:76) at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:216) at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:84) at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:44) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:73) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44) at org.eclipse.equinox.p2.operations.ProvisioningSession.performProvisioningPlan(ProvisioningSession.java:174) at org.eclipse.equinox.p2.operations.ProfileModificationJob.runModal(ProfileModificationJob.java:79) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 16:15:52.026 !MESSAGE Connection to http://download.eclipse.org/releases/helios/p2.index failed on No route to host: connect. Retry attempt 0 started !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576) at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98) at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342) at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639) at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:99) at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:95) at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedArtifactRepositories(ProvisioningContext.java:160) at org.eclipse.equinox.p2.engine.ProvisioningContext.getArtifactRepositories(ProvisioningContext.java:143) at org.eclipse.equinox.internal.p2.engine.DownloadManager.start(DownloadManager.java:72) at org.eclipse.equinox.internal.p2.engine.phases.Collect.completePhase(Collect.java:76) at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:216) at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:84) at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:44) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:73) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44) at org.eclipse.equinox.p2.operations.ProvisioningSession.performProvisioningPlan(ProvisioningSession.java:174) at org.eclipse.equinox.p2.operations.ProfileModificationJob.runModal(ProfileModificationJob.java:79) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !SESSION 2011-02-24 16:17:35.268 ----------------------------------------------- eclipse.buildId=M20100909-0800 java.version=1.6.0_24 java.vendor=Sun Microsystems Inc. BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US Command-line arguments: -os win32 -ws win32 -arch x86 !ENTRY org.eclipse.jface 2 0 2011-02-24 16:17:58.115 !MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation. !SUBENTRY 1 org.eclipse.jface 2 0 2011-02-24 16:17:58.115 !MESSAGE A conflict occurred for CTRL+G: Binding(CTRL+G, ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.search.declarations.in.workspace,Declaration in Workspace, Search for declarations of the selected element in the workspace, Category(org.eclipse.search.ui.category.search,Search,Search command category,true), , ,,true),null), org.eclipse.ui.defaultAcceleratorConfiguration, org.eclipse.ui.contexts.window,,,system) Binding(CTRL+G, ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.declarations.in.workspace,Find All Declarations In Workspace, , Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true), LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllDeclarationsAction@b7dc78)), ,,true),null), org.eclipse.ui.defaultAcceleratorConfiguration, com.adobe.flexide.editorcore.flexEditorScope,,,system) Binding(CTRL+G, ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.declarations.in.workspace,Find All Declarations In Workspace, , Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true), LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllDeclarationsAction@b7dc78)), ,,true),null), org.eclipse.ui.defaultAcceleratorConfiguration, com.adobe.flexbuilder.as.editor.context.packageexplorer,,,system) !SUBENTRY 1 org.eclipse.jface 2 0 2011-02-24 16:17:58.115 !MESSAGE A conflict occurred for CTRL+SHIFT+G: Binding(CTRL+SHIFT+G, ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.search.references.in.workspace,References in Workspace, Search for references to the selected element in the workspace, Category(org.eclipse.search.ui.category.search,Search,Search command category,true), , ,,true),null), org.eclipse.ui.defaultAcceleratorConfiguration, org.eclipse.ui.contexts.window,,,system) Binding(CTRL+SHIFT+G, ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.references.in.workspace,Find All References In Workspace, , Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true), LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllReferencesAction@eb4dba)), ,,true),null), org.eclipse.ui.defaultAcceleratorConfiguration, com.adobe.flexide.editorcore.flexEditorScope,,,system) Binding(CTRL+SHIFT+G, ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.references.in.workspace,Find All References In Workspace, , Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true), LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllReferencesAction@eb4dba)), ,,true),null), org.eclipse.ui.defaultAcceleratorConfiguration, com.adobe.flexbuilder.as.editor.context.packageexplorer,,,system) !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 17:19:49.036 !MESSAGE Connection to http://download.eclipse.org/eclipse/updates/3.6/p2.index failed on No route to host: connect. Retry attempt 0 started !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576) at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98) at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342) at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:115) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:100) at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$2.runModal(PreloadingRepositoryHandler.java:82) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !ENTRY org.eclipse.equinox.p2.core 4 0 2011-02-24 17:22:16.147 !MESSAGE Provisioning exception !STACK 1 org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://download.eclipse.org/eclipse/updates/3.6/content.xml. at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:189) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:66) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:88) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:746) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:651) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:115) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:100) at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$2.runModal(PreloadingRepositoryHandler.java:82) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) Caused by: java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:227) at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69) ... 1 more !SUBENTRY 1 org.eclipse.equinox.p2.repository 4 1002 2011-02-24 17:22:16.147 !MESSAGE Unable to read repository at http://download.eclipse.org/eclipse/updates/3.6/content.xml. !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:227) at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 17:22:37.156 !MESSAGE Connection to http://download.eclipse.org/eclipse/updates/3.6/p2.index failed on No route to host: connect. Retry attempt 0 started !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576) at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98) at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342) at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92) at org.eclipse.equinox.p2.engine.ProvisioningContext.loadMetadataRepository(ProvisioningContext.java:211) at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedMetadataRepositories(ProvisioningContext.java:194) at org.eclipse.equinox.p2.engine.ProvisioningContext.getMetadata(ProvisioningContext.java:275) at org.eclipse.equinox.internal.p2.director.SimplePlanner.gatherAvailableInstallableUnits(SimplePlanner.java:322) at org.eclipse.equinox.internal.p2.director.SimplePlanner.getSolutionFor(SimplePlanner.java:382) at org.eclipse.equinox.internal.p2.director.SimplePlanner.getProvisioningPlan(SimplePlanner.java:440) at org.eclipse.equinox.internal.p2.operations.PlannerResolutionJob.runModal(PlannerResolutionJob.java:76) at org.eclipse.equinox.p2.operations.ProfileChangeOperation.resolveModal(ProfileChangeOperation.java:115) at org.eclipse.equinox.internal.p2.ui.dialogs.ProvisioningOperationWizard$1.run(ProvisioningOperationWizard.java:207) at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121) !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 17:23:40.151 !MESSAGE Connection to http://download.eclipse.org/releases/helios/p2.index failed on Connection timed out: connect. Retry attempt 0 started !STACK 0 java.net.ConnectException: Connection timed out: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576) at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98) at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342) at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:115) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:100) at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$2.runModal(PreloadingRepositoryHandler.java:82) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !ENTRY org.eclipse.equinox.p2.core 4 0 2011-02-24 17:25:46.236 !MESSAGE Provisioning exception !STACK 1 org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://download.eclipse.org/releases/helios/content.xml. at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:189) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:66) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:88) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:746) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:651) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:115) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:100) at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$2.runModal(PreloadingRepositoryHandler.java:82) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) Caused by: java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:227) at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69) ... 1 more !SUBENTRY 1 org.eclipse.equinox.p2.repository 4 1002 2011-02-24 17:25:46.252 !MESSAGE Unable to read repository at http://download.eclipse.org/releases/helios/content.xml. !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:227) at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 17:26:07.261 !MESSAGE Connection to http://download.eclipse.org/releases/helios/p2.index failed on No route to host: connect. Retry attempt 0 started !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576) at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98) at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342) at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92) at org.eclipse.equinox.p2.engine.ProvisioningContext.loadMetadataRepository(ProvisioningContext.java:211) at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedMetadataRepositories(ProvisioningContext.java:194) at org.eclipse.equinox.p2.engine.ProvisioningContext.getMetadata(ProvisioningContext.java:275) at org.eclipse.equinox.internal.p2.director.SimplePlanner.gatherAvailableInstallableUnits(SimplePlanner.java:322) at org.eclipse.equinox.internal.p2.director.SimplePlanner.getSolutionFor(SimplePlanner.java:382) at org.eclipse.equinox.internal.p2.director.SimplePlanner.getProvisioningPlan(SimplePlanner.java:440) at org.eclipse.equinox.internal.p2.operations.PlannerResolutionJob.runModal(PlannerResolutionJob.java:76) at org.eclipse.equinox.p2.operations.ProfileChangeOperation.resolveModal(ProfileChangeOperation.java:115) at org.eclipse.equinox.internal.p2.ui.dialogs.ProvisioningOperationWizard$1.run(ProvisioningOperationWizard.java:207) at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121) !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 17:27:53.959 !MESSAGE Connection to http://download.eclipse.org/eclipse/updates/3.6/p2.index failed on No route to host: connect. Retry attempt 0 started !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576) at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98) at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342) at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639) at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:99) at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:95) at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedArtifactRepositories(ProvisioningContext.java:160) at org.eclipse.equinox.p2.engine.ProvisioningContext.getArtifactRepositories(ProvisioningContext.java:143) at org.eclipse.equinox.internal.p2.engine.phases.Sizing.completePhase(Sizing.java:91) at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:216) at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:84) at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:44) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:73) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44) at org.eclipse.equinox.internal.p2.ui.ProvUI.getSize(ProvUI.java:253) at org.eclipse.equinox.internal.p2.ui.dialogs.SizeComputingWizardPage$1.run(SizeComputingWizardPage.java:63) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 17:29:52.586 !MESSAGE Connection to http://download.eclipse.org/eclipse/updates/3.6/p2.index failed on No route to host: connect. Retry attempt 0 started !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576) at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98) at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342) at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639) at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:99) at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:95) at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedArtifactRepositories(ProvisioningContext.java:160) at org.eclipse.equinox.p2.engine.ProvisioningContext.getArtifactRepositories(ProvisioningContext.java:143) at org.eclipse.equinox.internal.p2.engine.phases.Sizing.completePhase(Sizing.java:91) at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:216) at org.eclipse.equinox.internal.p2.engine.EngineSession.rollBackPhase(EngineSession.java:239) at org.eclipse.equinox.internal.p2.engine.EngineSession.rollback(EngineSession.java:178) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:82) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44) at org.eclipse.equinox.internal.p2.ui.ProvUI.getSize(ProvUI.java:253) at org.eclipse.equinox.internal.p2.ui.dialogs.SizeComputingWizardPage$1.run(SizeComputingWizardPage.java:63) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 17:32:20.418 !MESSAGE Connection to http://download.eclipse.org/releases/helios/p2.index failed on No route to host: connect. Retry attempt 0 started !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576) at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98) at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342) at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639) at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:99) at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:95) at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedArtifactRepositories(ProvisioningContext.java:160) at org.eclipse.equinox.p2.engine.ProvisioningContext.getArtifactRepositories(ProvisioningContext.java:143) at org.eclipse.equinox.internal.p2.engine.phases.Sizing.completePhase(Sizing.java:91) at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:216) at org.eclipse.equinox.internal.p2.engine.EngineSession.rollBackPhase(EngineSession.java:239) at org.eclipse.equinox.internal.p2.engine.EngineSession.rollback(EngineSession.java:178) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:82) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44) at org.eclipse.equinox.internal.p2.ui.ProvUI.getSize(ProvUI.java:253) at org.eclipse.equinox.internal.p2.ui.dialogs.SizeComputingWizardPage$1.run(SizeComputingWizardPage.java:63) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 17:34:05.854 !MESSAGE Connection to http://download.eclipse.org/eclipse/updates/3.6/p2.index failed on No route to host: connect. Retry attempt 0 started !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576) at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98) at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342) at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639) at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:99) at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:95) at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedArtifactRepositories(ProvisioningContext.java:160) at org.eclipse.equinox.p2.engine.ProvisioningContext.getArtifactRepositories(ProvisioningContext.java:143) at org.eclipse.equinox.internal.p2.engine.DownloadManager.start(DownloadManager.java:72) at org.eclipse.equinox.internal.p2.engine.phases.Collect.completePhase(Collect.java:76) at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:216) at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:84) at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:44) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:73) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44) at org.eclipse.equinox.p2.operations.ProvisioningSession.performProvisioningPlan(ProvisioningSession.java:174) at org.eclipse.equinox.p2.operations.ProfileModificationJob.runModal(ProfileModificationJob.java:79) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !ENTRY org.eclipse.equinox.p2.repository 2 0 2011-02-24 17:35:51.153 !MESSAGE Connection to http://download.eclipse.org/releases/helios/p2.index failed on No route to host: connect. Retry attempt 0 started !STACK 0 java.net.NoRouteToHostException: No route to host: connect at java.net.PlainSocketImpl.socketConnect(Native Method) at java.net.PlainSocketImpl.doConnect(Unknown Source) at java.net.PlainSocketImpl.connectToAddress(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73) at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65) at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707) at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361) at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387) at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397) at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142) at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889) at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576) at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:98) at org.eclipse.equinox.internal.p2.repository.FileReader.sendRetrieveRequest(FileReader.java:342) at org.eclipse.equinox.internal.p2.repository.FileReader.readInto(FileReader.java:288) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:71) at org.eclipse.equinox.internal.p2.repository.RepositoryTransport.download(RepositoryTransport.java:127) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:718) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:639) at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:99) at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:95) at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedArtifactRepositories(ProvisioningContext.java:160) at org.eclipse.equinox.p2.engine.ProvisioningContext.getArtifactRepositories(ProvisioningContext.java:143) at org.eclipse.equinox.internal.p2.engine.DownloadManager.start(DownloadManager.java:72) at org.eclipse.equinox.internal.p2.engine.phases.Collect.completePhase(Collect.java:76) at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:216) at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:84) at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:44) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:73) at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44) at org.eclipse.equinox.p2.operations.ProvisioningSession.performProvisioningPlan(ProvisioningSession.java:174) at org.eclipse.equinox.p2.operations.ProfileModificationJob.runModal(ProfileModificationJob.java:79) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !SESSION 2011-02-24 17:55:26.783 ----------------------------------------------- eclipse.buildId=M20100909-0800 java.version=1.6.0_24 java.vendor=Sun Microsystems Inc. BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US Command-line arguments: -os win32 -ws win32 -arch x86 !ENTRY org.eclipse.jface 2 0 2011-02-24 17:55:48.126 !MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation. !SUBENTRY 1 org.eclipse.jface 2 0 2011-02-24 17:55:48.126 !MESSAGE A conflict occurred for CTRL+G: Binding(CTRL+G, ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.search.declarations.in.workspace,Declaration in Workspace, Search for declarations of the selected element in the workspace, Category(org.eclipse.search.ui.category.search,Search,Search command category,true), , ,,true),null), org.eclipse.ui.defaultAcceleratorConfiguration, org.eclipse.ui.contexts.window,,,system) Binding(CTRL+G, ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.declarations.in.workspace,Find All Declarations In Workspace, , Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true), LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllDeclarationsAction@1031d18)), ,,true),null), org.eclipse.ui.defaultAcceleratorConfiguration, com.adobe.flexide.editorcore.flexEditorScope,,,system) Binding(CTRL+G, ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.declarations.in.workspace,Find All Declarations In Workspace, , Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true), LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllDeclarationsAction@1031d18)), ,,true),null), org.eclipse.ui.defaultAcceleratorConfiguration, com.adobe.flexbuilder.as.editor.context.packageexplorer,,,system) !SUBENTRY 1 org.eclipse.jface 2 0 2011-02-24 17:55:48.126 !MESSAGE A conflict occurred for CTRL+SHIFT+G: Binding(CTRL+SHIFT+G, ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.search.references.in.workspace,References in Workspace, Search for references to the selected element in the workspace, Category(org.eclipse.search.ui.category.search,Search,Search command category,true), , ,,true),null), org.eclipse.ui.defaultAcceleratorConfiguration, org.eclipse.ui.contexts.window,,,system) Binding(CTRL+SHIFT+G, ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.references.in.workspace,Find All References In Workspace, , Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true), LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllReferencesAction@16b1b61)), ,,true),null), org.eclipse.ui.defaultAcceleratorConfiguration, com.adobe.flexide.editorcore.flexEditorScope,,,system) Binding(CTRL+SHIFT+G, ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.references.in.workspace,Find All References In Workspace, , Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true), LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllReferencesAction@16b1b61)), ,,true),null), org.eclipse.ui.defaultAcceleratorConfiguration, com.adobe.flexbuilder.as.editor.context.packageexplorer,,,system) !SESSION 2011-02-24 22:28:43.609 ----------------------------------------------- eclipse.buildId=M20100909-0800 java.version=1.6.0_24 java.vendor=Sun Microsystems Inc. BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US Command-line arguments: -os win32 -ws win32 -arch x86 !ENTRY org.eclipse.jface 2 0 2011-02-24 22:30:06.562 !MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation. !SUBENTRY 1 org.eclipse.jface 2 0 2011-02-24 22:30:06.562 !MESSAGE A conflict occurred for CTRL+G: Binding(CTRL+G, ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.search.declarations.in.workspace,Declaration in Workspace, Search for declarations of the selected element in the workspace, Category(org.eclipse.search.ui.category.search,Search,Search command category,true), , ,,true),null), org.eclipse.ui.defaultAcceleratorConfiguration, org.eclipse.ui.contexts.window,,,system) Binding(CTRL+G, ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.declarations.in.workspace,Find All Declarations In Workspace, , Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true), LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllDeclarationsAction@1731b2f)), ,,true),null), org.eclipse.ui.defaultAcceleratorConfiguration, com.adobe.flexide.editorcore.flexEditorScope,,,system) Binding(CTRL+G, ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.declarations.in.workspace,Find All Declarations In Workspace, , Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true), LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllDeclarationsAction@1731b2f)), ,,true),null), org.eclipse.ui.defaultAcceleratorConfiguration, com.adobe.flexbuilder.as.editor.context.packageexplorer,,,system) !SUBENTRY 1 org.eclipse.jface 2 0 2011-02-24 22:30:06.562 !MESSAGE A conflict occurred for CTRL+SHIFT+G: Binding(CTRL+SHIFT+G, ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.search.references.in.workspace,References in Workspace, Search for references to the selected element in the workspace, Category(org.eclipse.search.ui.category.search,Search,Search command category,true), , ,,true),null), org.eclipse.ui.defaultAcceleratorConfiguration, org.eclipse.ui.contexts.window,,,system) Binding(CTRL+SHIFT+G, ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.references.in.workspace,Find All References In Workspace, , Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true), LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllReferencesAction@1fdc405)), ,,true),null), org.eclipse.ui.defaultAcceleratorConfiguration, com.adobe.flexide.editorcore.flexEditorScope,,,system) Binding(CTRL+SHIFT+G, ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.references.in.workspace,Find All References In Workspace, , Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true), LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllReferencesAction@1fdc405)), ,,true),null), org.eclipse.ui.defaultAcceleratorConfiguration, com.adobe.flexbuilder.as.editor.context.packageexplorer,,,system)
