The CFB Plugin for Mac breaks when installed within Flash Builder Burrito. The first time you run Burrito w/CFB perspective, it works fine. On subsequent openings, the CF code editing no longer works and the code just displays as plain text. Also, the Flash Builder Burrito main menu Search button changes to %LabelSearch. Only way to use CFbuilder with Burrito is to uninstall and reinstall the CFB plugin. After reinstall, CF code editing works and the main menu returns to just Search. It is repeatable on every reopening of Flash Builder. Frequent re-installs of CFB are required as a workaround. This was not an issue with Flash Builder 4 w/CFB plugin. Only with Burrito.
Don Kerr
It Appears CF Builder is not compatible with Flash Builder Burrito, since it doesn't support Cocoa.
"Mac OS X we’ve updated Flash Builder to use the “Cocoa” version of Eclipse and are removing support for the older “Carbon” version."
When can we expect the plugin to work with Burrito? Possibly a preview?
It is really preventing me from using the FB Previews since I need to do a lot of Flex/CF together all day.
I wish CFB and FB releases were kept in sync. Unless I'm missing something?
Don Kerr
Manager, Space City AUG
CFB1 will not be supported with Burrito. The next version, Storm should work ok with Burrito as it will support Cocoa version of eclipse.
Can you tell me is this limitation only with Mac/Eclipse Cocoa?
Also, can you give me an approx date on the Storm release (if possible)?
Thanks.
Yes this is the only limitaion on Mac.On windows, you can have them together(i.e FB Burrito and CF Builder 1), even though it is not there in the support matrix.
Good news is that all is working well with Storm/FB on Mac.
