No Repeat Region
Jul 07, 2006 Jul 07, 2006
I invoked a CFC to give me the results of a query inside the CFC. How to I
make it so only the newest record shows and not all the results? Do I have
to set the repeat region manually to only show one or is there something I
can add to the <cfoutput query="news">?
<tr>
<td class="maintext_bold">#DateFormat(news.Date,"mm/
dd/ yyyy")#</td>
</tr>
<tr>
<td class="maintext">#news.Story#</td>
</tr>
</cfoutput>
Wally Kolcz
Developer / Support
Advanced techniques
1.2K
You could put your displaying code within
<cfif news.Date GT someDate>
<!--- display news --->
</cfif>
If showing the newest result is all you need, then it might be more efficient to do that already at the query. For example, by selecting news "where date > #someDate#".
Jul 08, 2006 Jul 08, 2006
?? You lost me on that one ??
I made two suggestions. Other posters have in fact repeated them.
1) Get all news, but display just the new news (inefficient if this is all there is to it)
<cfset someDate = createdate(2006,4,22)>
<tr>
dd/ yyyy")#</td>
</tr>
<tr>
</tr>
</cfif>
</cfoutput>
2) (a) code the query to select the latest news since a given date
<cfquery name="news" datasource="#Request.MainDSN#">
SELECT News_ID, Story,Date
FROM ms411.news
WHERE Date > #createodbcdatetime(someDate)#
ORDER BY Date DESC
</cfquery>
(b) code the query to select the latest news item (more or less Dan Bracuk's suggestion)
FROM ms411.news
WHERE Date = (SELECT MAX(date) FROM ms411.news )
</cfquery>
Maybe I am wrong about your post..but there is NO comparison date. The site
news may be updated once a day, once every 6 months, or once every 16 years.
I just need the last item shown.
However it has been solved using a MySQL SQL string.
Thanks.
I actually showed you an example of code "to select the latest news item" - 2(b). In any case, it's nice you've found a solution.
It pulls the correct record, but the code wants to create a repeat region
for all the records. i only want it to show the latest record since it is
pulling decendingly.
Did I miss something?
If you have control over the cfc, enhance it so that it gives you what you need. Otherwise, do a query of queries on your return variable.
I am new to components. Here is what I have.
<cfcomponent>
<cffunction name="LatestNews" access="public" returntype="query">
SELECT News_ID, Story,Date FROM ms411.news ORDER BY Date DESC
</cfquery>
<cfreturn news>
</cffunction>
</cfcomponent>
How can I get that to show 1 result (the newest)?
To get the most recent record, do this
select News_ID, Story, Date
FROM ms411.news
where somefield = (select max(somfield) from ms411.news)
Somefiled can be either news_id or date, depending on whether you want the last record added, or the one with the most recent date.
Nothing to do with being a component. Just put a where clause in your
query so that it only returns the one record you want to display.
If you want to to do both, then use <cfarguments...> to pass is a
parameter to dynamically determine when to return one record and when to
return many.
> <cfcomponent>
> </cfquery>
> <cfreturn news>
> </cffunction>
> </cfcomponent>
What do you put in a WHERE clause to get it to only show the newest result?
The news is not time sensitive so I cannot compare it to anything. The
client may only put one news update every 60 day or 6 years.
So then you just want one record returned.
SELECT TOP 1 works for MS databases, I'm not sure for Oracle and mySQL
or others.
Yeah, I am using MySQL 5
A quick goggle looks like for MySql it is limit
SELECT *
FROM aTable
LIMIT 1
Here are other dbms versions that may also work.
--SQL:
TOP 3 * from mytable
--ACCESS:
select top 3 * from (select * from mytable)
--ORACLE:
ROWID <=3
Thanks. The LIMIT 1 works fine if you put it on the very end. I put is
before the ORDER BY and it blew up.
why not just do it in the <cfoutput>
<cfoutput query="whatever" startrow="#recordcount# maxrows="1">
</cfoutput>
That will give you last record of query.
</cfoutput>
Because it is very inefficient.
Documentation
