1. Re: Unable to Capture SD video
Keano66 Feb 28, 2011 4:36 AM (in response to Keano66)This guy is having the same problem - only with HDV material:
3. Re: Unable to Capture SD video
Keano66 Feb 28, 2011 7:55 AM (in response to Harm Millaard)Just tried that, Harm - without success. Still not capturing. Just to add some more info - I updated all windows files including Service Pack 1 for Windows 7 - don't know if this has anything to do with the issue. Anyway, I will try to capture on a different pc...
4. Re: Unable to Capture SD video
Keano66 Feb 28, 2011 8:54 AM (in response to Keano66)SUCCESS!...I seem to have found a solution - still not sure what happened but when I installed the firewire card, I disabled the onboard 1394 connection in the bios ( I didn't think I would need it.) Anyway, I re-enabled it and connected my XL2 to the onboard 1394 firewire and it worked! BTW, this was all done on my main Video editing PC and not on the different pc, I said I would.
5. Re: Unable to Capture SD video
davidbeisner2010 Feb 28, 2011 10:17 AM (in response to Keano66)Glad its working for you! I'm guessing somewhere in the back-and-forth between firewire card/onboard, the "new" drivers were getting used and when you rolled them back, you still had the firewire disabled by mistake. Good luck!
6. Re: Unable to Capture SD video
Keano66 Feb 28, 2011 11:05 AM (in response to davidbeisner2010)Thanks David...the capture window looks better than ever!
