SOLVED
Error when Creating a ServiceClientFactory instance JAVA API
Avatar
Level 2
When invoking Assembling a PDF document  quick start I'm having a compilation error when creating a ServiceClientFactory instance:
//Create a ServiceClientFactory instance
ServiceClientFactory myFactory = ServiceClientFactory.createInstance(connectionProps);
The error is: The type com.adobe.idp.Context cannot be resolved. It is indirectly referenced from required .class files
All the required jars are a path.
What esle can be a problem ?
Thanks, Yan
1 Accepted Solution
Avatar
Correct answer by
Level 10
UM.JAR file likely to be missing.
Download the file from here and add it to your classpath.
Let me know if it works.
Nith
Avatar
Correct answer by
Level 10
Nith
Avatar
Level 8
The com.adobe.idp.Context is in the adobe-usermanager-client.jar file.  Make sure that is in your build path.
Avatar
Level 2
Thanks! After adding the um.jar it compiled but now it fails in a run time with error:
java.lang.NoClassDefFoundError: org/apache/axis/soap/SOAPConstants
although we are using the axis.jar.
Any clue what is the problem ? Which JVM should we use?
Avatar
Level 8
Since you are using SOAP, you need to have the AXIS jars available.  They are in the LiveCycle_ES_SDK\client-libs\thirdparty directory:
 activation.jar (required for SOAP mode)
axis.jar (required for SOAP mode)
commons-codec-1.3.jar (required for SOAP mode)
  commons-collections-3.1.jar  (required for SOAP mode)
commons-discovery.jar (required for SOAP mode)
commons-logging.jar (required for SOAP mode)
dom3-xml-apis-2.5.0.jar (required for SOAP mode)
jaxen-1.1-beta-9.jar (required for SOAP mode)
jaxrpc.jar (required for SOAP mode)
log4j.jar (required for SOAP mode)
mail.jar (required for SOAP mode)
saaj.jar (required for SOAP mode)
wsdl4j.jar (required for SOAP mode)
xalan.jar (required for SOAP mode)
xbean.jar (required for SOAP mode)
xercesImpl.jar (required for SOAP mode)
