Has anyone heard of this problem while using Kaspersky? This was originally posted in 2008 by another member - Flaven. I'll just use his post because it describes my problem exactly. His solution was to disable his antivirus software (Threatfire) while using Robohelp, but I do not have permission to do that. Is there another way around this problem?
The problem is that this suddenly started happening to a project I've had no problems with since I started it several months ago. When I generate Webhelp, it prduces a varying number of zero-byte topic files (the files are created, but contain nothing). That is, one time there will be 15 zero-byte files, the next time 5, the next time 10, and so on. The files are random; it's never the same files.
I can copy the files out of my project folder into the generated Webhelp folder, and the Webhelp project will run fine on my PC, but when I then try to publish the project to a server (or another folder on my hard drive), I get an access denied error about half way through. The last published file is bsscftp.txt.
For a manual fix, I can replace the zero-byte files, and copy to the server, but I cannot publish from within Robohelp.
To be more specific about the error I get when trying to publish, it says, "
A sharing violation has occurred on bsscftp.txt."
I just had my network support to disable Kaspersky and it made no difference
, so I'm still needing help with this problem. Thanks in advance!
Can you please provide some more information regarding the zero byte issue.
Praful
Yes...thank you for replying.
I am using RH8.
I have previous projects where this did not happen.
It started on my current project which would generate and complile fine three months ago.
I have created a new project with the same results.
The files are never the same; every time I generate I will get a different set of zero-byte files. The previous zero-byte files will be fine, but a different set will be effected.
Update...
The other day when I asked my network support to disable Kaspersky, they did not. I asked them again today (after uninstalling and reinstalling RH) to try it one more time.
Disabling Kaspersky solved the problem. Now if I could just get someone to tell me how to get around this permanently because they will not remove Kaspersky from my PC.
I've used Kaspersky in the past and found their support very helpful. I think it worth asking them.
Your IT peeps might not remove Kaspersky, but they might be amenable to disabling certain folders on your machine (as we were able to convince our folks here). Keep it simple, though: make sure that all writers are using the same folder structure for all projects (wouldn't want to confuse or over-stress those IT folks).
Good luck,
Leon
Thank you Leon and Peter.
My Network "peeps" say they are working on a solution so I am hoping they
will consider disabling for certain folders. Would you happen to know if
that would be my project folders and/or also my webhelp folders? I generate
into My Documents/Project Name folder, not into the My Documents/My RoboHelp
Projects/Project Name folder. (My last several projects were generated this
way and I did not have a problem.)
Also, I am the only one in this office that uses RoboHelp. Thanks!
I would get them to give you both source and target locations if it comes to that. There may be a different solution.
Speaking of IT peeps, in some organizations, they assign all My Documents folders as some kind of virtual mapped network drives.
You're better off placing at least your project source files at C:\first_project\source, C:\second_project\source, etc. The output could remain in the My Documents area, though.
Good luck,
Leon
Thanks Leon,
I will give that a try next time.
