Hi All,
I am new for Flash builder. i try to connect sharepoint webserviecs with flex.
i could not connect i got an error.
my sharepoint webservices link like this :
http://localhost/teamsites/BS/Demo/Lists/TickerNews/_vti_bin/lists.asmx
but i try to connect i got below text error:
Unable to retrieve operations and entities from the specified WSDL.
Reason :
There was an error during service introspection.
Details:
WSDLException: faultCode=OTHER_ERROR: Unable to resolve imported document at 'http://eworkspace/teamsites/BS/Demo/Lists/TickerNews/_vti_bin/lists.asmx'.: java.io.IOException: Server returned HTTP response code: 407 for URL: http://localhost/teamsites/BS/Demo/Lists/TickerNews/_vti_bin/lists.asmx
pls help me anybody know the solution.
kind regards
siraj
Please find tutorials in this URL http://sujitreddyg.wordpress.com/flash-builder-4/#webservice
Hope this helps.
Please find more details on response code 407 here http://www.checkupdown.com/status/E407.html
Shouldn't you be appending "?wsdl" to the URL pointing to asmx to fetch the WSDL?
Hope this helps.
Hi sujeet
Thanks for your replay
I am new for the flex developer. If you have any sample example could you send me. Its great help for me.
kind regards
sirajudeen
Date: Mon, 28 Feb 2011 08:04:47 -0700
To: ksiraj2002@hotmail.com
Subject: Flash builder 4 with sharepoint
Hope this helps.
Hope this helps.
Hi Sujit
Really you save my time.. Thanks a lot.
Actually i was working in flash cs5, right now i switch over to flex builder4.
When i run the file flex builder 4 (bin-debug folder create swf file).
and again export to release folder (i get bin-release folder in that folder i got swf file).
I copy the swf file to put on the swf it's give me error (security). When i was playing in flexbuilder its working perfect.
When i put into my webserver to access the sharepoint its give me security error.
If you know please give me the solutions.
i thing its realted to local and network properties...
kind regards
sirajudeen
Date: Wed, 2 Mar 2011 06:49:20 -0700
Hope this helps.
Please try and share details of the error. Also see if this URL helps http://www.adobe.com/devnet/flashplayer/articles/cross_domain_policy.html
Hi
I already try this one. but i think small need to change in flash builder complier ex:-local_US instead need to use any network syntax..
kind regards
sirajudeen
Date: Wed, 2 Mar 2011 09:29:13 -0700
Can you please share the error details.
Thanks.
HI Sujeet
Flash CS5 is it support for iphone.
what is the basic step to create flash cs5 for iphone application
kind regards
sirajudeen
You can find details here http://www.adobe.com/devnet/logged_in/abansod_iphone.html
