document.yourformname.submit didn't work.
But then discovered that the href value needs to be empty (or
"#") to work. This code works: (rollover images with the submit()
code):
<a href="#"
onClick="javascript:submit()"
onmouseover="MM_swapImage('Image9','','images/change-meeting-date.png',1)"
onmouseout="MM_swapImgRestore()">
<img src="images/blank-hidden-area.png"
name="Image9"
width="111"
height="11"
border="0"
id="Image9" />
</a>
When, in DW, you add the rollover image, you need to leave
the href value empty. I suppose that lets the submit button use the
<cfform action...> value as the results page, letting the
form values pass to the results page.
Now, the next step is to have two different rollover images
with submits() that point to two different result pages, while
still using one cfform. (Two submits in one form, each submit
pointing to a different results page.)
...Rick...
