1. Re: Get average brightness of a JPG movieclip?
kglad Feb 22, 2011 9:58 PM (in response to xTLS)use the bitmapdata class and loop through its pixels. you probably only need to check 1/4 or 1/9 the pixels to get an average brightness.
2. Re: Get average brightness of a JPG movieclip?
xTLS Feb 22, 2011 10:12 PM (in response to kglad)Ah yeah, that's what I remember messing with before. Well, I'll try it again, but if you've got any more specific advice that'd be great, otherwise I'll just come back if I need more help. Thanks!
3. Re: Get average brightness of a JPG movieclip?
Lee Burrows Feb 24, 2011 11:22 AM (in response to xTLS)hi
you could also use the histogram() method of BitmapData to get the 'amount' of colour in the image:
var v:Vector.<Vector.<Number>> = myBitmapDataObject.histogram(new Rectangle(...));
this returns a Vector containing 4 Vectors (one for R,G,B and A) which contain 256 items - so it may be quicker to sum and average 3x256 values rather than bitmapWidth x bitmapHeight values (especially as getPixel is relatively slow)
4. Re: Get average brightness of a JPG movieclip?
xTLS Feb 28, 2011 6:02 PM (in response to Lee Burrows)Thanks Lee, that sounds like a good approach, but I don't know how to use vectors so I don't know how to implement it. Could you explain?
5. Re: Get average brightness of a JPG movieclip?
Lee Burrows Mar 1, 2011 12:03 PM (in response to xTLS)hi
this should do the trick (assuming you have a BitmapData object called "bmd"):
var v:Vector.<Vector.<Number>> = bmd.histogram(new Rectangle());
var r:Number = 0; var g:Number = 0;
var b:Number = 0;
for (var i:uint=0;i<256;i++) { r += i*v[0][i]/255; g += i*v[1][i]/255;b += i*v[2][i]/255;
} var totalPixels:uint = bmd.rect.width*bmd.rect.height; r /= totalPixels; g /= totalPixels; b /= totalPixels; var brightness:Number = (r+g+b)/3;
You should now have a value between 0 and 1 for the image brightness (this is off the top of my head so there may be a bug in there somewhere...)
For general info on using Vectors, see: http://www.mikechambers.com/blog/2008/08/19/using-vectors-in-actionscript-3-and-flash-play er-10/
6. Re: Get average brightness of a JPG movieclip?
xTLS Mar 2, 2011 3:16 PM (in response to Lee Burrows)Thanks Lee, I tried it but the R, G, and B values always return 0. Any thoughts?
EDIT: By removing "new Rectangle()" from the function call I think I got it partly working, but return values range from .75 to 1.
For PNGs with transparency it reads fully transparent pixels as white; guess I can't do anything about that.
7. Re: Get average brightness of a JPG movieclip?
Lee Burrows Mar 2, 2011 3:20 PM (in response to xTLS)hi
yes - my bad; new Rectangle() should be null (or empty)
make sure your bitmapData object is not transparent (ie: third param of constructor is false)
for transparent bm's, this seems to work (but havent tested thoroughly)
var v:Vector.<Vector.<Number>> = bmd.histogram(null);
var r:Number = 0;
var g:Number = 0;
var b:Number = 0;
var a:Number = 0;
r += i*v[0][i]/255;
g += i*v[1][i]/255;
b += i*v[2][i]/255;
a += i*v[3][i]/255;
r /= totalPixels;
g /= totalPixels;
b /= totalPixels;
a /= totalPixels;
var brightness:Number = a*(r+g+b)/3;
8. Re: Get average brightness of a JPG movieclip?
FeZEC Mar 3, 2011 5:19 AM (in response to Lee Burrows)There is one more trick, instead of all teh calculations. Though i like the idea of the histogram.
Shrink the jpg to 1x1 pixel width.
And check what the color is. that will give you an average color.
Then you can get the brightness of that rgb by returning the perceived LUMA
var luma:int = red * red * .241 + green * green * .691 + blue * blue * .068
9. Re: Get average brightness of a JPG movieclip?
xTLS Mar 7, 2011 3:51 PM (in response to Lee Burrows)Lee, is the new variation you game me supposed to ignore alpha? It gives me a slightly different value but it's still reading fully transparent pixels as pure white. It doesn't matter if I set the transparency in the BMD constructor to false or true.
Lazec, that's an interesting idea, I'll try it out. Do you know how reliable it is? I need a completely reliable method for what I'm doing.
EDIT: I just realized I was doing var bmd:BitmapData = new BitmapData(testImage.width,testImage.height,true) but I should have been doing var bmd:BitmapData = new BitmapData(testImage.width/4,testImage.height/4,true). I don't understand why it needs to be that way yet, but that fixes the values only ranging from .75 to 1. It doesn't help with the transparent pixels reading as pure white but maybe it will be less of an issue.
EDIT2: Yeah, after fixing the problem with the dimensions, Lee's method is definitely accurate enough for my purposes, even with the transparency problem. Awesome, thanks again Lee.
10. Re: Get average brightness of a JPG movieclip?
xTLS Sep 12, 2012 12:44 PM (in response to xTLS)Coming back to this a year and a half later, I've had to expand the number of images that are being checked, and now the inaccuracy from reading transparent pixels as white is too severe. Anyone know a better way to do this?
EDIT:
How many times did I think I got this right before I actually did? Anyway, HERE IS THE REAL SOLUTION. Less complicated than what I was trying before.
protected static function getAverageColor(image:MovieClip):Number {
var bmp:BitmapData = new BitmapData(image.width,image.height, true, 0x00000000);
//bmp.draw(image);
bmp.draw(image.getChildAt(0));
var v:Vector.<Vector.<Number > > = bmp.histogram();
var r:Number = 0;
var g:Number = 0;
var b:Number = 0;
var a:Number = 0;
for (var i:int=0; i<256; i++) {
r += i * v[0][i] / 255;
g += i * v[1][i] / 255;
b += i * v[2][i] / 255;
a += i*v[3][i]/255;
var brightness:Number = (r+g+b)/(3*a);
bmp.dispose();
trace("brightness: " + brightness);
return brightness;
Returns a value between 0 and 1, with .5 being halfway between pure white and pure black.
Message was edited by: xTLS
