3 Replies Latest reply on Mar 7, 2011 2:49 PM by Ricavir
    Fireworks FXG import
    Ricavir Level 1
      I have a problem while importing FXG content from FW to FC.
      Before explaining the problem, I'm going to introduce the context :
      I'm leading a team which is composed by designers and developpers : we are 12 persons.
      Our goal is to produce an AIR application.
      Our Workflow :
      PhotoShop (CS5) : graphic library
      Fireworks (CS5) : user interface (one file for each main function of the application)
      Flash Catalyst (CS5) : conversion into flex components
      Flash Builder (CS5) : application developement (based on cairngorm 3 and parsley)
      I have no problems between Photoshop and Fireworks or between Flash Catalyst and Flash Builder.
      Problem :
      I want to import our user interface designed with Fireworks into Flash Catalyst using FXG format.
      It works quite well but FW states are imported at same level of FW pages
      It's a problem because my designers have to remove these states and recreate them at the right level on FC.
      Is it a FW export issue ? If yes, would it be fixed ?
      Is there a better workflow solution ?
      My goal is to simplify as much as possible the workflow : whe have more than 500 screens to create ....
        • 1. Re: Fireworks FXG import
          Ricavir Level 1
          No answer ? No ideas ??
          I can't find any information about FW states exported to FC !
          Please, help me
          • 2. Re: Fireworks FXG import
            Chris W. Griffith Adobe Community Professional
            Unfortunately, Flash Catalyst's support of FXG from Fireworks is not the best. I would suggest that you create clones of the Fireworks document that contain just the section you need to work with. I have found if I focus on just the smaller parts of the application, my workflow is smoother. I know it is tempting to bring in the whole ui at once, but keeping it smaller and modular as worked for me.
            Good Luck!
            Chris Griffith
            1 person found this helpful
            • 3. Re: Fireworks FXG import
              Ricavir Level 1
              Hello Chris,
              Thank you for your experience... I will take it into account ;-)
              Actually, We plan to have more or less 20 pages per file.
              Do you know if FXG between FW and FC will be improved in next release ?
              Ricardo
