SOLVED
Looping through records in XML Variable !!
Avatar
Level 4
I am getting no way how to do this. I am getting the below XML from a custom DSC component. Now I need to process it.
<root>
    <records total_records="4">
        <record>
            <jobno>1122</jobno>
            <cust_name>Abhinav</cust_name>
            <email>abhinavs@plabs.com</email>
            <stat>1</stat>
        </record>
        <record>
            <jobno>2233</jobno>
            <cust_name>Doctor Dhober</cust_name>
            <stat>0</stat>
        </record>
        <record>
            <jobno>4666</jobno>
            <cust_name>Vinau Dubey</cust_name>
            <stat>1</stat>
        </record>
        <record>
            <jobno>7677</jobno>
            <cust_name>Nelesh Poda</cust_name>
            <stat>0</stat>
        </record>
    </records>
</root>
Now I need to loop through every record & do some stuff for each one. In my process I have to send a mail to each of the user in the XML file. I tried it using SET VALUE's Node Set Functions, but not successful. Any help.
Thanks.
Abhinav
1 Accepted Solution
Avatar
Correct answer by
Level 8
Your xpath doesn't match your XML - you are missing the root node in your xpath expression:
Expression: /process_data/myXML/records/record[1]/email
should be:
           /process_data/myXML/root/records/record[1]/email
When you build your loop there is one other thing to be careful of.  If you evaluate an xpath variable inside of another xpath expression, it gets inserted as a string.  This happens even if the variable is an integer.  For example:  If I have an integer variable counter which is set to 3 and evaluate:
     /process_data/myXML/root/records/record[/process_data/@counter]/email    The xpath expression will insert "3" (a string) and not an integer as you would expect.  The result will not be the third node. This can be a source of frustration and its hard to debug.
Instead, use the number function inside the expression:
  /process_data/myXML/root/records/record[number(/process_data/@counter)]/email
I've attached a sample process that shows this.
Avatar
Level 4
I tried in set value opr:
/process_data/@strEmail
Expression: myXML is XML var in process
/process_data/myXML/records/record[1]/@email
Result expected
strEmail = 'abhinavs@plabs.com'
But didn't getting it. Pls help.
Thanks.
Abhinav
Avatar
Employee
In your xml document, email is a node - not an attribute.
The xPath expression should be:
The location uses the @strEmail notation because as an LC process variable, it's a simple value (String) and treated as an attribute of the process.
Avatar
Level 4
Thanks Marcel for your response. I tried the way you told, but still I am not getting the node value from xml.
strEmail is still null/blank. I checked myXML variable, it holds the proper XML as above.
I am stucked in it, help!!.
Abhinav
Avatar
Correct answer by
Level 8
should be:
