1 Reply Latest reply: Mar 9, 2011 7:14 AM by Colin Brougham RSS
    Syncing Audio with video
    rowby Community Member
      Hello
      I have a short sequence of clips where I deleted my video, leaving my audio.
      Now I want to bring back the video for each clip.
      So I am looking for the in and out points of the audio clips so I can match them up with the orginal video clip.
      When I look at properties on the audio clip it just gives me duration of the clip.
      When I hover over the audio clip it just gives me in and out points based on where the clip is at the point in the timeline.
      What can I bring up that will let me find the ins and outs of the audio clips so that I can match them up with the same in and outs of the video.
      (I'm getting an inkling of how to do this as I write this question.  But I'll let the others here make their suggestions in case there are various ways to do this, that would be helpful to all.)
      Rowby
        • 1. Re: Syncing Audio with video
          Colin Brougham Community Member
          Use Match Frame. Park the CTI at the beginning of the audio clip in the sequence, and make sure your audio tracks are targeted. Press the M key; this will load the original master clip into the Source Monitor cued to the frame you're trying to match. Mark an in point (I key), and then right-click the time ruler in the Source Monitor and select Go to Clip Marker > Audio Out. Mark an out point (O key). Drag just the video to your sequence, so that it matches your audio. Select video and audio, and Link the clips. Repeat.
