Locked
Unable to click the "Adobe Flash Player Settings"
Mar 06, 2011 Mar 06, 2011
Whenever the following window pops up, regardless of browser I use, I click click and click and nothing happens:
On the other hand, when I try installing a screensaver I just got:
Something is certainly wrong with Flash on my PC. I've installed, uninstalled, re-installed, re-uninstalled it multiple times, restarting and all that. Same old. Windows 7 64 and stuff. Kinda need a hand here.
12.8K
Deleted User
Mar 09, 2011 Mar 09, 2011
Hi Shonendo,
Did you follow the info in my Post#8 to you? If none of that solved the issue, then I think what I would do is go back to the Global Settings and make sure all of the Settings are as you want them. You can also, enter this website in a "trusted" zone.
Not sure if that's the exact wording, but the effect is the same.
Make sure you didn't click a Setting to NOT allow the Setting that you now want. The Global Settings are not easy to select. One must do a lot of reading and some of the I
Guest
The alerts you posted beg a couple of questions.  The second includes what version of Flash are you trying to install?  Did you make sure that you've uninstalled any older versions?  I just downloaded and installed the "latest" version and it appears to be 10,2,152,32.  http://www.adobe.com/software/flash/about/  will tell you what version is currently running on your computer.
The first alert you posted is more disturbing.  Adobe Flash Player Settings is simply advising you that some other something or other is requesting access to your camera and mic.  Whatever that is is blued out.  Something is missing in translation; the screen is requesting one click, either on the ALLOW or DENY button.  So the question is, what is trying to get access and what are you clicking, and what started all this?
"You have version 10,2,154,12 installed"
I'm pretty sure the version I've installed is the latest one. Uninstalled everything flash related and re-installed.
The first alert gives me the option  to ALLOW or DENY, with the problem that no matter how many times I click either option, absolutely nothing happens and the alert remains there. This example uses nothing more than a simple chat room, but I've also seen this alert elsewhere with the same problem.
Guest
Hi Shonendo, frustratedfrequently pointed out that the website is asking permission. As long as that is ok with you, then that's fine. You are having a problem either allowing or denying. That has to do with your second screenshot.
It appears to me that even tho you have the latest version of FP Installed, it is not working. That is why you received that message from Adobe at that site.
Using IE, go to Tools, Manage addons and look under "Show"(very light text) in All addons for Shockwave Flash Object. Make sure it is Installed and Enabled.
Let me know,
eidnolb
But I don't even use IE... But I did what you said anyways, and there's nothing Flash/Shockwave related in the list. Only things listed under Adobe are some Contribute thing and other PDF thing...
Guest
You didn't mention any browser at all actually. Had you not mentioned Win7, I would not even have known what OS you were using:-)
Since Flash Player works thru the browsers it is helpful to know which browsers are Installed.
So, then what browser or browsers are you using?  And you don't have Flash Player Installed in IE? How then do you Update Windows?
A Service Pack 1 came out recently, did you Install that for Win7?
Regardless, that message from Adobe tells you you need Flash Player Installed. So whatever browser you were using when trying to Install that Screensaver isn't working, since it needs Flash Player.
Also you may want to check and make sure any Screensaver you want to Install is compatible.
thanks,
eidnolb
I use Chrome 9.0.597.107 which has Flash listed under the plugins.
I have Windows 7 x64 Service Pack 1
Guest
Ok, thanks. That's no problem. However that Screensaver appears to require the ActiveX Control which Internet Explorer uses. So you need to Install Flash Player into IE.
Download and SAVE to your Desktop the Installer for IE- use the EXE Installer
http://www.adobe.com/products/flashplayer/fp_distribution3.html
Close all browser windows, you only want to be looking at your Desktop.
Disable any messenger services, as yahoo, msn, etc in the system tray(area near the clock)
Disable your Anti-Virus (you will be offline)
Be sure to use the Administrator Account.
Run the Uninstaller and when finished, Reboot(restart) your computer.
Re-enable your Anti-Virus
Then go to this test site and test the IE browser
You should see the Flash logo animate and the version of Flash Player will be displayed.
You can re-read that 2nd screenshot, but that is what my understanding of that message is.
eidnolb
Guest
On the Global Settings, See if you access any from the main site:
http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager.html
Also I don't know for sure, but you may need to set this Setting also:
http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager03.html
Then you may want to take a look at this thread: Post#25
http://forums.adobe.com/thread/128188
I've never had any problems using the Global Settings and don't really know why some users can't.
Hope that is some help.
eidnolb
Mar 08, 2011 Mar 08, 2011
Thanks, I have seen to get around the screensaver issue, but so far no change regarding being able to click the "Allow" or "Deny" pop up box thingy...
Guest
If your problem is as you wrote:
but so far no change regarding being able to click the "Allow" or "Deny" pop up box thingy..."
then you are reading the wrong thread.
Guest
Hi Shonendo,
Make sure you didn't click a Setting to NOT allow the Setting that you now want. The Global Settings are not easy to select. One must do a lot of reading and some of the Individual Settings work with the others. Some can even overrule others.
Other than that, you could contact the website and perhaps they would have information on their end.
That is all I would be able to suggest.
Thanks and I hope you get it solved.
eidnolb
It worked. Thanks for the help and stuff.
Guest
Geez, Shonendo, don't keep me in suspense, LOL What exactly worked?
We have this issue from time to time and it is difficult to find how to solve it. So some feedback would be so helpful for other users.
Thanks for marking your thread as answered too!
eidnolb
Guest
hello i am having the same problem but could not use the same procedures. i have windows 7 and the latest flash player and can not change the settings not even from global settings. please help! i use ie usually but mozilla too both are the same no "allow" "deny" or any of the other settings.
try to use another browser, such as mozilla firefox, maybe it helps you
Firefox makes no difference. Same exact problem.
Nov 24, 2011 Nov 24, 2011
Screenshot at 2011-11-24 17:02:37.png
I am running Ubuntu 11.10, and I have upgraded to Adobe Flash 11.1.102.55.  I have tried this in Mozilla, Google Chrome, and Chromium, but have always encountered the same problem.  It is usually a game site such as kongregate or notdoppler, but I am unable to click Allow, Deny, or anything.  I have right-clicked, and checked settings, global settings, and even added the websites to the trusted list, still no dice.  Please help, this is driving me insane!!!!
