i add 5 subforms on the form.
3 subform is positioned at the top of page (doc header). 1 at the bottom.
and 1 flowed between top and bottom subforms.
in the flowed subform one table binded to wsdl service. and.....
when table contains 16 rows i can see correct hedder on the first page and correct bottom on the second.
but when it can't fit in two pages.... on the first page i can see only some table rows without doc header (smaller then it can fit - 7 rows), second page filled complitely whith 10 rows, and third page contains bottom of table and !!! doc header subforms content.
Total Likes
It usually depends on how the Pagination settings and how the Subform content is set (Flowed/ Positioned)..
Probably it would help if I can see the form.. You can send it to LiveCycle9@gmail.com..
If you are sending the form, please send the sample data file also for testing if you have..
Srini
Total Likes
Hi. Send file by email. and after solv problem.
I remove subforms, generated automaticaly by datasource. after table become root element between hedder and footer subforms and... thats all, pagination work eccellent.
thanks for all...
Total Likes
