Hi
I am trying to access an xml file in flash AS3 which is created from server side language (ASP). But unfortunately it throws an error message like
TypeError: Error #1085: The element type "input" must be terminated by the matching end-tag "</input>"
But when I open the page in browser it has written the xml nodes perfectly and I can save the xml and use locally from the flash. There is no error at this time.
And intersting thing is I am not using any tag like <input> </input>
xmlLoader.load(new URLRequest('http://search.oracle.com/search/feed?q=%22target%20region%22:%22north%20america%22%20%22start%20date...%20&group=EventsRSS&start=1&search_p_custom_att=start%20date&search_p_custom_att=event%20type&search_p_custom_att=city&num=1000'));
xmlLoader.addEventListener(Event.COMPLETE, LoadXML);
xmlLoader.addEventListener (ProgressEvent.PROGRESS, loading);
If I pass this url in browser it returns a proper xml and I can use it inside the flash. I don't know what is wrong here.
When I trace the PROGRESS of the xml loading it breaks in between and it returns 0 for e.bytesTotal value.
I am sure the xml is created properly but I am not sure where is the problem. My AS3 code also perfect and it doesn't throws any error.
Please give me a solution on this.That would be highly appreciable.
Thanks in Advance.
your xml needs a wrapper node. does it have one?
Yes I have a wrapper node in the xml
My xml starts from <channel> and end with </channel> in the browser. Could you please check the xml path in the URLRequest which I provided
doesn't return xml for me.
copy and paste the xml returned to your complete function.
Please run this link and click view source you will get the xml node generated. There is a whitespace in the of the xml. I have used ignoreWhitespace=true and that is not the real issue
http://search.oracle.com/search/feed?q="target region":"north america" "start date":>3/12/2011 | &group=EventsRSS&start=1&search_p_custom_att=start date&search_p_custom_att=event type&search_p_custom_att=city&num=1000
This is a huge xml so I cannot paste here fully. That is why I am giving this link. Please check it and let me your comments.
Thank you for your reply
that xml loads fine for me. did you copy the xml to a local file and test loading that local file?
Hi, Yes the xml is loading fine here and I checked locally and its working fine. But when it run from the server/ generating dynamically I am getting this error. Please help me out
Thnak you
Hi
I am getting the same problem when you run normal xml it works fine but when you use xml in a php file on server to do the same thing all hell
breaks lose.
TypeError: Error #1085: The element type "param" must be terminated by the matching end-tag "</param>".
I hopw some one can assist.
I just did a little test using the code below, and retrieved the XML without issue... Did you escape the quotes in the request URL?
var u:URLLoader = new URLLoader();
var r:URLRequest = new URLRequest("http://search.oracle.com/search/feed?q=\"target region\":\"north america\" \"start date\":>3/12/2011 | &group=EventsRSS&start=1&search_p_custom_att=start date&search_p_custom_att=event type&search_p_custom_att=city&num=1000");
u.addEventListener(Event.COMPLETE, done);
u.load(r);
function done(e:Event):void
var a:XML = new XML(e.target.data);
trace(a);
I noticed you guys are talking about grabbing the XML and getting it to work. I am having trouble with the same error #1085 in a video that should be displaying, but getting that error. Is there a way to do a FireBug type of in browser edit to get the video to play?
