Hello,
I'm using Premiere Pro CS5 on a Mac with a single monitor. I would like to see the full screen preview on this monitor, hiding all GUI elements.
By reading around, I could only find the suggestion of selecting the Preview pane and press the ~ or ` key. Unfortunatly, it seems that this shortcut only triggers the Maximize or Return to the Original Size commands. GUI elements remain in the display.
Is there some preference to select somewhere?
Thank you, Paolo
That's as close as you can get with Premiere; it doesn't do a single-monitor fullscreen the way FCP does.
Make a feature request if this is something you'd like to see: Adobe Feature Request/Bug Report Form
Thanx Colin. Yes, I'll file a request, since I'm more and more editing far from my studio.
Paolo
Hi guys!
There is a fullscreen mode for a preview in Premiere Pro CS6!
First, You press ~ or ` (which is the same key) and when You have Your preview window maximised, You need to press Ctrl + ~
You'll get Your Fullscreen mode. To restore it to normal size press Esc.
Best regards,
Dima
Whatever happened to Colin Brougham? He was such a prolific contributor!
Are you there Colin?
Yes he is still around but not on these forums.
