We're running 7,0,1,116466 on Windows 2000 box.
All works just fine.
Except one client using an iMac 10.2.8, 800 MHz power PC G4
and using Safari browser 1.0.3 (v85.8.1).
She gets the debug screen even though debugging is only for
one IP that is set.
and it says a file is not found when we KNOW it's there.
Dump shows (the domain has been renamed intentionally):
anyone have a clue?
File not found: /
www.domain.org/pages.cfm
Resources:
Check the ColdFusion documentation to verify that you are
using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser
Mozilla/5.0 (Macintosh; U; PPC Mac OS X; en-us)
AppleWebKit/85.8.5 (KHTML, like Gecko) Safari/85.8.1
Remote Address
75.3.9.215
Referrer
http://www.domain.org/home.cfm?CFID=146695&CFTOKEN=94091470
Date/Time
11-Jul-06 07:11 PM
Stack Trace
coldfusion.runtime.TemplateNotFoundException: File not found:
at coldfusion.filter.PathFilter.invoke(PathFilter.java:83)
at
coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:69)
at
coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:52)
at
coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)
at
coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
at
coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
at
coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at
coldfusion.filter.RequestThrottleFilter.invoke(RequestThrottleFilter.java:115)
at coldfusion.CfmServlet.service(CfmServlet.java:107)
at
coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:78)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
at
jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at
jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:257)
at
jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:541)
at
jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:204)
at
jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:318)
at
jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:426)
at
jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:264)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
