1. Re: Missing info in manuals
Ned Murphy Mar 16, 2011 7:14 AM (in response to barpos)Aside from needing to add the two containers, you need to add some content that actually displays something you can see... your textfields are empty.
2. Re: Missing info in manuals
kglad Mar 16, 2011 7:14 AM (in response to barpos)using addChild() adds displayobjects to the displaylist.
your problem is not adding to the displaylist. your problem is that your displayobjects have no content.
if you assigned text to your textfields or even just enabled their border, you would see content. they'll all be overlapping but that's another issue.
3. Re: Missing info in manuals
barpos Mar 16, 2011 7:31 AM (in response to Ned Murphy)Sorry! I didn't realized that. I copied and pasted the code from the manual.
The following does work, just not sure it is the RIGHT way though:
var mySquare_mc:MovieClip = new Square();
mySquare_mc.x = 300;
mySquare_mc.y = 300;
var myContainer:Sprite = new Sprite();
myContainer.addChild(mySquare_mc);
addChild(myContainer);Thanks!
Ron
4. Re: Missing info in manuals
kglad Mar 16, 2011 8:26 AM (in response to barpos)is there any purpose served by using myContainer? if not, remove that part of your code:
addChild(mySquare);
5. Re: Missing info in manuals
barpos Mar 16, 2011 8:46 AM (in response to kglad)Yes, there is. I don't want the tweens (and their associated symbol objects) I create dynamically to mix with my stage objects. Reason, I'll be making a FOR structure routine soon that'll automatically resize display objects on the stage (dragged on in Flash). As I've realized, tweens cannot be resized the same way as other display objects, therefore one has to execute the tween code separately and alter its property arrays accordingly to reflect needed changes.
Anyhow, this thread is somewhat related to my other thread. As you suggested, I'll be moving my loaded images into a movieclip container. Actually, I won't need to make the container visible after all. addTarget() seems to act like addChild(), displaying the symbol passed to it. <s>
Ron
6. Re: Missing info in manuals
kglad Mar 16, 2011 9:22 AM (in response to barpos)ok.
p.s. please mark helpful/correct responses.
