I'm having trouble with these tests. I'm always getting Timeout Occurred for my sequence in the test testOnLogout.
Any ideas?
Timeout Occurred before expected eventTimeout Occurred before expected event
Error: Timeout Occurred before expected event
at org.flexunit.internals.runners.statements::ExpectAsync/handleAsyncTimeOut()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at org.flexunit.async::AsyncHandler/handleTimeout()
package tests.view
import flexunit.framework.Assert;
import mx.events.FlexEvent;
import org.flexunit.async.Async;
import org.fluint.sequence.SequenceRunner;
import org.fluint.sequence.SequenceSetter;
import org.fluint.sequence.SequenceWaiter;
import org.fluint.uiImpersonation.UIImpersonator;
import views.LoginForm;
public class TestLoginForm
private var view:LoginForm;
[Before(async,ui)]
public function setUp() : void
view = new LoginForm;
Async.proceedOnEvent( this, view, FlexEvent.CREATION_COMPLETE, 600 );
UIImpersonator.addChild( view );
[After(async,ui)]
public function tearDown():void
UIImpersonator.removeChild( view );
view = null;
[Test(async, ui)]
public function testOnLogout():void {
var passThroughData:Object = new Object();
passThroughData.username = 'test';
passThroughData.password = 'test';
passThroughData.selectedIndex = 0;
var sequence:SequenceRunner = new SequenceRunner( this );
sequence.addStep( new SequenceSetter( view.username, {text:passThroughData.username} ) );
sequence.addStep( new SequenceWaiter(view.username, FlexEvent.VALUE_COMMIT, 400 ) );
sequence.addStep( new SequenceSetter( view.password, {text:passThroughData.password} ) );
sequence.addStep( new SequenceWaiter( view.password, FlexEvent.VALUE_COMMIT, 400 ) );
sequence.addStep( new SequenceSetter( view.domain, {selectedIndex:passThroughData.selectedIndex} ) );
sequence.addStep( new SequenceWaiter( view.domain, FlexEvent.VALUE_COMMIT, 400 ) );
view.onLogout();
sequence.addAssertHandler( handleOnLogout, passThroughData );
sequence.run();
protected function handleOnLogout( passThroughData:Object ):void {
Assert.assertEquals(
view.username.text,passThroughData.username,
view.password.text,passThroughData.password,
view.domain.selectedIndex,passThroughData.selectedIndex);
So, I am taking a guess here that what you want is the onLogout() call to happen as part of the sequence. But this is not what your code does. Sequences are defined and then run when you call the run() method.
Here you are calling the onLogout method in the middle of defining the sequence.. then sometime later (likely after the logout is done) your sequence begins waiting for things to happen... and times out because nothing is happening.
I think what you want here is to use the SequenceCaller cla
I think what you want here is to use the SequenceCaller class to actually execute the onLogout as part of the sequence.
Mike
thx mike, you mean like this: I'm still getting timeouts
[Test(async, ui)]
var sequence:SequenceRunner = new SequenceRunner(this);
sequence.addStep(new SequenceSetter(view.username, {text:passThroughData.username}));
sequence.addStep(new SequenceWaiter(view.username, FlexEvent.VALUE_COMMIT, 400));
sequence.addStep(new SequenceSetter(view.password, {text:passThroughData.password}));
sequence.addStep(new SequenceWaiter(view.password, FlexEvent.VALUE_COMMIT, 400));
sequence.addStep(new SequenceSetter(view.domain, {selectedIndex:passThroughData.selectedIndex}));
sequence.addStep(new SequenceWaiter(view.domain, FlexEvent.VALUE_COMMIT, 400));
sequence.addStep(new SequenceCaller(view,view.onLogout ));
sequence.addAssertHandler(handleOnLogout, passThroughData);
sequence.run();
FYI
public function onLogout():void
username.text = '';
password.text = '';
domain.selectedIndex = 0;
