4 Replies Latest reply: Mar 18, 2011 1:17 AM by Matt Paintin Branched to a new discussion. RSS
    Inverse Position Expression...still need some help please!!
    Matt Paintin Community Member
      Following up a post from a few days ago....
      Im creating a hand made anamorphic lens flare and I want to control the position of the elements in it with a null
      Mylenium kindly pointed me to his site which has great projects to download but its beyond my math capabilities and I havent been able to get my head around it and apply it to my project.
      I have this expression which has got me started
      pRef=thisComp.layer("null 1").position;
      X=thisComp.width-pRef[0];
      Y=thisComp.height-pRef[1];
      [X,Y]
      But if I want to add additional lens flare elements that move at a different relative position, this expression wont do it. Its only good for one element.
      I only want a few elements in the flare
      Can anyone suggest a simple way to do this? Im only looking at having 2 or 3 flare elements in it...nothing heavy.
        • 1. Re: Inverse Position Expression...still need some help please!!
          Mylenium CommunityMVP
          Sorry for not checking back, but the current forum problems make it  difficult to post without being kicked out every 2 minutes.... What you  want is very much in the project I was pointing you to - you need a  relative offset along an imaginary view axis, so let's try this by  commenting some updated code for the position of a secondary element a  bit (parts you won't need not included):
          cSource3D=thisComp.layer("Light"); //reference a 3D light as source
          cSource2D=cSouce3D.toComp([0,0,0]); //convert to screen coordinates
          cMiddleX=thisComp.width*0.5; //midpoint X
          cMiddleY=this Comp.height*0.5; //midpoint Y
          cDiffX=cSource[0]-cMiddleX; //position difference X
          cDiffY=cSource[1]-cMiddleY; //position difference Y
          cAngle=Math.atan2(cDiffY,cDiffX); //find angle
          cOffset=200; //distance from middle
          X=cMiddleX+Math.sin(cAngle)*cOffset;
          Y=cMiddleY+Math.cos(cAngle)*cOffset;
          [X,Y]
          Mylenium
          • 2. Re: Inverse Position Expression...still need some help please!!
            Thanks Mylenium
            I totally understand your problems replying....its not a problem....I know you are a busy guy! Im just grateful you have taken the time to help out!
            Forgive my ignorance with the math on this subject
            So if I am to understand it correctly to I just apply the complete revised expression to my secondary element?
            • 3. Re: Inverse Position Expression...still need some help please!!
              cSource2D=cSource3D.toComp([0,0,0]); //convert to screen coordinates
              cMiddleY=thisComp.height*0.5; //midpoint Y
              cDiffX=cSource2D[0]-cMiddleX; //position difference X
              cDiffY=cSource2D[1]-cMiddleY; //position difference Y
              [X,Y]
              Yes, simply copy&paste the above code ( I corrected the typos) to your secondary element and adjust the cOffset variable to suit (you could tie it to a slider, if needed; negative values move in opposite direction). Make sure to adjust the reference to the light in your comp (or your 3D Null). If you use an expression Point control or the Lensflare effect on a solid, you don't need the first line and the second line would then look something like that:
              cSource2D=thisComp.layer("Lensflare").effect("Lens Flare")("Flare Center")
              Mylenium
              • 4. Re: Inverse Position Expression...still need some help please!!
                Thats great Mylenium
                Again, thank you so much for taking the time to explain the details.
