Show 3 replies
1. Re: Why is the output file jerky ?
Rick Gerard Mar 12, 2011 3:14 AM (in response to ryan_khoo)The default render settings use Quicktime Animation codec at best quality. These files will not playback smoothly because the data rate is too high for the hard drives to keep up with. The animation codec is a lossless codec designed not designed for playback.
Final Cut uses compressed codecs designed for playback as the default. I'd suggest that you open up the help files (F1) and read the entire section on Rendering and Exporting (link).
2. Re: Why is the output file jerky ?
Szalam Mar 12, 2011 9:36 AM (in response to ryan_khoo)This page explains what Rick said even more.
3. Re: Why is the output file jerky ?
ryan_khoo Mar 19, 2011 10:21 AM (in response to Rick Gerard)Thanks Rick & Szalam for the response !
Really appreciate it !
Cheers
