SQL help
Jul 15, 2006 Jul 15, 2006
I need some help with a SQL statement.
I have 2 tables in a database. One is 'team' and the other is 'users'. The
share the common key 'username'
What I would like is to query both tables using a join and then output only
the username that do not appear in both lists.
For example:
Team: Users:
Bob Bob
Tammy Tammy
Joe Joe
Mike
The results would only be Mike's information.
Please help!
Wally Kolcz
Developer / Support
Advanced techniques
300
Advisor ,
You did not specify which DB you are using and that is very important for this kind of query.
SQL like this will work for quality or STANDARDS COMPLIANT DB's:
SELECT
U.UserName,
T.UserName
FROM
USERS U
FULL OUTER JOIN
TEAM T ON U.UserName = T.UserName
WHERE
U.UserName IS NULL
OR
T.UserName IS NULL
Participant ,
If your data base supports a full outer join you might get by with one statement something like:
select nvl(a.username,b.username) from team a full outer join users b on a.username = b.username
where a.username is null or b.username is null
Otherwise you will need to do something like one of the following:
(select username from team
minus
select username from users)
union
(select username from users
minus
select username from team)
select a.username from team a left outer join users b on a.username = b.username
where b.username is null
union
select b.username from users b left outer join team a on b.username = a.username
I am using a MySQL 5 database, if that helps.
Thanks you.
I don't know if it matters, but I just want the list from the 'users' table
and never from the 'team' table.
It is to allow team members that are not assigned to a project to be added
at a different time.
After reading the MySQL site, will this work to only show the results in
table 1 that do not exist in table 2?
SELECT table1.* FROM table1 LEFT JOIN table2 ON table1.id=table2.id WHERE
table2.id IS NULL
Advisor ,
Yes, it should.
Documentation
