query1 from db1 and update db2 from the values extracted from query1
Jul 14, 2006 Jul 14, 2006
HI,
i have this html query report . works great
it queries from the db1 and outputs in html format.
my next assignment is to update a database db2 by inserting values from the query results i got from db1
how do i do this??
thanks in advance.
Advanced techniques
521
The best approach is to not do it at all, just use the data from db1.
If that is not an option, see if there is a way to do it outside cold fusion.
If you can't do that, see if you can link the db's somehow, then it's a single query.
The last resort would be,
<cfoutput query = "yourquery">
<cfquery>
insert, ...
closing tags.
For the record, I did one of those last resort things today.
Jul 15, 2006 Jul 15, 2006
why did i you write "best approach is to not do it at all"
what are the short comings of writing a application like this?
also
the query results extracted from db1 (database 1 (oracle9)) is still needed to update the db2 (database 2 (oracle9))
is there another way of building an application???
Jul 16, 2006 Jul 16, 2006
quote:
because you already have the data.
Jul 17, 2006 Jul 17, 2006
the data is from a query result to html output.
you mentioned" see if there is a way to do it outside cold fusion."
please explain?
also, what is a good systematic apporach for this problem?
thanks
Contributor ,
All in one step (assuming same schema, you'll need to supply qualifiers and/or may have to the DBA's involved if different schema or instances). Even more efficiently you should write a Stored Procedure right in Oracle and call it from CF. At any rate syntax on either side would be:
Insert INTO tblForDB2
Select whatever AS col1nameinDB2, whatever AS col2nameinDB2, etc. FROM tblForDB1
Alternatively but much slower
<cfloop query="db1Query">
INSERT into tblForDB2 (col1nameDB2, col2nameDB2, etc)
VALUES #whateverfromDB1#, #whateverfromDB1#, etc. with or without quotes as needed.
</cfloop>
Jul 23, 2006 Jul 23, 2006
it is different dataabse
Documentation
