When I start Flash Builder, I always get the error message "Workspace in use or cannot be created, choose a different one." The Workspace Launcher always points to the directory "C:\Users\Administrator\Adobe Flash Builder 4". I point to the workspace I want and click the "Use this as default" option, but on the next start, it's back to the default Administrator directory. I have no other choices in the Workspace combobox If I start Flash Builder using Run As Administrator, I get the choices of workspaces.
How can I have the workspace choices when I run Flash Builder normally?
By the way, this is running on Windows 7 where I do have administrative rights.
Was Flash Builder installed by Administrator?
I'll get the installer guys onto this thread, but as a workaround, could you try start Flash Builder as user Admistrator, change your workspace (just like you did).
Now, restarting as yourself should do the trick.
-Anirudh
I installed Flash Builder using Run as Administrator. I've changed the workspace when I start Flash Builder as Administrator and set that as default, but when I restart Flash Builder normally, it always gives me the error "Workspace in use or cannot be created, choose a different one." and points to the "C:\Users\Administrator\Adobe Flash Builder 4" directory.
Thanks for trying that out. I've forwarded this thread, so the installer guys should be able to shed some light on this.
-Anirudh
Meanwhile, to unblock you, maybe you should install Flash Builder when logged in with your username.
From what I understand about this, the workspace data is stored in C:\users\your_username and since your_username is only accessible by administrator, you're running into this problem.
-Anirudh
I have uninstalled Flash Builder and reinstalled it.The first few times I clicked on the installer, I got the message that I didn't have the privileges to run it (even though I have Local Administrative rights). Then I was able to install it without right clicking "Run as Administrator", but I am still getting the "Workspace Unavailable" error message and the default workspace points to "C:\Users\Administrator\Adobe Flash Builder 4"
i had this issue also and just defined a new workspace then set that as default.
