Hi Everyone,
I am trying to finish creating a mouse based slider and want to dynamically create movieclip boxes inside one master movieclip. This is so I can slide the master MC left and right. Also, I want to add an image to each box. I'm getting closer but need some serious expert guidance. Right now, I can't figure out how to attach the image to the boxes.
All of the dynamic stuff happens in a for loop, and when each image is loaded, it fires the Event Listener to a function to attach it. But being outside that foor loop, the new function can't reference the objects. If you have some guru in you, your time is most appreciated. I am way past a deadline and in some trouble at work.
Here is the code I am talking about, followed by the FLA link with all the code:
var gBox:Object = new Object(); function init(e:Event = null):void { removeEventListener(Event.ADDED_TO_STAGE, init); container = new MovieClip(); addChild(container); container.y = 110; for (var i:int = 0; i < boxCount; i++) { nextXPos = i*(boxWidth+boxMargin); trace("NXP: " + nextXPos); gBox["box"+i] = new Sprite() with(gBox["box"+i]){ container.graphics.beginFill(0xff1111); container.graphics.drawRect(nextXPos, 0, boxWidth, boxHeight+boxMargin); x=nextXPos; imgLoader = new Loader(); imgLoader.contentLoaderInfo.addEventListener(Event.COMPLETE, addThumbnail); imgLoader.load(new URLRequest("http://www.yazizle.com/files/test_img01.png")); addEventListener(MouseEvent.CLICK, doButton); } container.addChild(gBox["box"+i]); } stage.addEventListener(MouseEvent.MOUSE_MOVE, mouseMoveHandler); container.addEventListener(MouseEvent.ROLL_OVER, rollOverHandler); container.addEventListener(MouseEvent.ROLL_OUT, rollOutHandler); }
and here is the link tto the FLA: http://www.yazizle.com/files/mouseSlider.zip
your code's not legible.
