Topic List and Content Build Tags
Mar 23, 2011 Mar 23, 2011
Topic List view does not show Content Build Tag properties for all topics that have them.
Using Windows 7, 64-bit, RH9-HTML.
I double-checked the properties window for a few of the topics and they do indeed have a build tag selected, but that tag does not show up in the Content Build Tag column in the Topic List view.
I am not exactly sure when this changed, but I recently upgraded from RH8 to RH9.  Could have been then.
It appears that the tags are working for my generated layout.
Only other commonality seems to be that they are all topics not in a TOC (TOC=no), but there might be others.  Is this by design?
591
LEGEND , Mar 23, 2011 Mar 23, 2011
Hi there
I think we are comparing spiders to hedgehogs here. Build tags may be applied to content inside a topic. (Words, paragraphs, characters, Images, etc.) and those are Content level tags. But Build Tags may also be applied to the entire topic. There are two columns you may elect to show in the Topic List pod. You are showing the Content tag column. If you right-click the label bar and enable the Topic level column, you should then see that what you presented in the first image is listed the
Hi there
Does anything change if you clear the CPD and allow RoboHelp to rebuild it?
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7, 8 or 9 within the day!
Adobe Certified RoboHelp HTML Training
SorcerStone Blog
RoboHelp eBooks
Nope...I renamed the CPD and let RH rebuild it, but no, the build tags are still not in the Topic List view.
I also now have one broken link that was not there before.
Hello again
Sooo, are you maybe instead saying you don't see a column for the build tags? Or do you have the column present, but some tags are listed and some aren't?
Cheers... Rick
SorcerStone Blog
RoboHelp eBooks
Hi...the column is there (Detail View) and the tags are there for some topics.
For the ones that are not showing in the Topic List, the Topic Properties do have them marked and these topics used to (RH8?) have their tags show up in the List.
Thanks for your replies.
Hi there
I think we are comparing spiders to hedgehogs here. Build tags may be applied to content inside a topic. (Words, paragraphs, characters, Images, etc.) and those are Content level tags. But Build Tags may also be applied to the entire topic. There are two columns you may elect to show in the Topic List pod. You are showing the Content tag column. If you right-click the label bar and enable the Topic level column, you should then see that what you presented in the first image is listed there as it appears to have a tag applied at the topic level.
Cheers... Rick
SorcerStone Blog
RoboHelp eBooks
Ah-ha!!  Thank you so much...the upgrade to RH9 must have reset the columns in my list view.  I am glad it was just operator error.
RoboHelp Documentation
Download Adobe RoboHelp
