When I read Email with CFPOP,
ok, no problem.
To answer the mail, i put a form with a hidden field containing the incoming Mail body (to resend)
Sometimes, depending of incoming mails,
the hidden field display unwanted caracters (caracters contained at end of the body of original mail)
How to get reed of this ?
That should be a known problem ?
Thanks for any help.
Pierre.
Just a thought, to advance in my diagnostic,
Hidden fields do not support HTML inside ?
Thanks for help again.
Pierre.
As far as I can see, the Mail Body must be cleaned up before I can reuse it
in an hidden field ?
Any idea ? Thanks.
Use a session variable instead of a hidden field.
Ok, thanks, I will try.
Thanks a lot,
seems working,
I will go farther with more sofisticated mails to see.
Pierre.
Thanks, does work fine.
Pierre.
