I want to capture long webpages or scrolling windows using RoboScreen Capture. There is no such mode availble in the menu.
Help would be appreciated.
Deepti
Welcome to the forum.
Sorry but that is not an option using that tool. You need something like SnagIt.
Thank you for the welcome.
Please have a look at this post
http://help.adobe.com/en_US/FrameMaker/8.0/help.html?content=Chap-23-TechCommSuite_2.html
OR
http://help.adobe.com/en_US/framemaker/using/WS4279000F-ACA5-403b-B46F-BD80A744B03B.html
Under "You can use RoboScreen Capture to perform the following tasks: ", check out the fourth bulleted point .
I am using RoboHelp 8 and RoboScreen Capture is part of it.
Deepti
did you try the option Capture > Extended Active Window(Shift+F11). this allows to specify the width and height. so you can change the height and can specify a bigger height and robocapture will capture the whole web page.
thanks
Praful
Apologies. Adobe must have slipped that one in since I last used it.
Hi Praful,
This works. Thanks a lot.
P.S:- I clicked Helpful Answer instead of Correct Answer. When I tried to do it again, I got the message "Unexpected Error".
Deepti
