I am in the process of creating a Flashbuilder application that will log onto Adobe Connect 8 and draw a whole lot of info off of the server.
I am able to log onto Adobe Connect from my application.
Now I would like to have some text that says "Welcome Dimitri Merritt" (obviously whatever the users name is). If I have read the documentation correctly I should be able to us x-user-id. I have tried this but without luck. Can somebody please help me out?
Dimtiri
ps I am not sure if I am supposed to post this request here or in the Flex forum. When I read the intro "letter" to this forum I was convinced that I should post the request in the Flex forum. I then read in the Flex forum a big announcement that the Flashbuilder forum is now open and if you are using Flashbuilder one must come here i.e. I hope this does not offend anybody if I am mistaken.
Ok I figured this one out with help form Kapil (thanks Kapil).
Here are a few lines of code that is needed:
<s:HTTPService id="myPersonalInfo" fault="faultHandler(event) resultFormat="e4x" result"personalInfo(event)"/>
Then create a function e.g.
private function requestPersonalInfo():void{
domainUrl="your url.com";
personalInfoRequest="";
personalInfoRequest=domainUrl+api_xml_string;
personalInfoRequest+="common-info";
myPersonalInfo.url=personalInfoRequest;
myPersonalInfo.send();
private funtion personalInfo(event:ResultEvent):void{
personalName=event.result.common.user.name;
Username.text="Welcome" + personalName;
Thats it.
