I would like to use Flash Builder to create an AIR application that will talk to Adobe Connect. Is there anywhere I can go in order to read up on how to do this?
Thank you
Dimitri
Ok I figured this one out with help form Kapil (thanks Kapil).
Here are a few lines of code that is needed:
<s:HTTPService id="myPersonalInfo" fault="faultHandler(event) resultFormat="e4x" result"personalInfo(event)"/>
Then create a function e.g.
private function requestPersonalInfo():void{
domainUrl="your url.com";
personalInfoRequest="";
personalInfoRequest=domainUrl+api_xml_string;
personalInfoRequest+="common-info";
myPersonalInfo.url=personalInfoRequest;
myPersonalInfo.send();
private funtion personalInfo(event:ResultEvent):void{
personalName=event.result.common.user.name;
Username.text="Welcome" + personalName;
Thats it.
