i have this error :
Fonts should be embedded for any text that may be edited at runtime, other than text with the "Use Device Fonts" setting. Use the Text > Font Embedding command to embed fonts.
Attempting to launch and connect to Player using URL D:\iagora\novoguest\gbook_v5.swf
[SWF] D:\iagora\novoguest\gbook_v5.swf - 99599 bytes after decompression
*** Security Sandbox Violation ***
Connection to http://127.0.0.1/novo_guest/inputGBook.php halted - not permitted from file:///D|/iagora/novoguest/gbook%5Fv5.swf
-- Untrusted local SWFs may not contact the Internet.
SecurityError: Error #2028: O arquivo SWF Local-with-filesystem file:///D|/iagora/novoguest/gbook%5Fv5.swf não pode acessar o URL http://127.0.0.1/novo_guest/inputGBook.php.
at flash.net::URLStream/load()
at flash.net::URLLoader/load()
at gbook_v5_fla::Gbook_1/checkForm()[gbook_v5_fla.Gbook_1::frame1:50]
at gbook_v5_fla::Gbook_1/clickHandler()[gbook_v5_fla.Gbook_1::frame1:5]
Cannot display source code at this location.
this is my code :
stop();
gb_btn.addEventListener(MouseEvent.CLICK, openHandler);
function clickHandler(event:MouseEvent):void {
checkForm();
function openHandler(event:MouseEvent):void {
if (currentLabel=="closed") {
nextFrame();
} else if (currentLabel=="open") {
prevFrame();
function checkForm():Boolean {
// ensure that the username_ti field isn't blank.
if (alias.text.length == 0) {
// if the username_ti field is empty, display an error message in the status_lbl Label instance.
aviso.htmlText = "<font color=\"#ff0000\">Insira um Nome.</font>";
// exit the checkForm function.
return false;
// if the password_ti TextInput instance is blank,
// display an error message in the status_lbl Label instance and exit the checkForm function.
if (mail.text.length == 0) {
aviso.htmlText = "<font color=\"#ff0000\">Insira um email válido.</font>";
return false;
if (titulo.text.length == 0) {
aviso.htmlText = "<font color=\"#ff0000\">Insira um titulo.</font>";
return false;
if (mensagem.text.length == 0) {
aviso.htmlText = "<font color=\"#ff0000\">insira uma mensagem.</font>";
return false;
var gbookVars:URLVariables = new URLVariables();
gbookVars.alias = alias.text;
gbookVars.titulo = titulo.text;
gbookVars.mail = mail.text;
gbookVars.mensagem = mensagem.text;
var gbookRequest:URLRequest = new URLRequest();
gbookRequest.method = URLRequestMethod.POST;
gbookRequest.data = gbookVars;
gbookRequest.url = "http://127.0.0.1/novo_guest/inputGBook.php";
var gbookLoader:URLLoader = new URLLoader();
gbookLoader.dataFormat = URLLoaderDataFormat.VARIABLES;
gbookLoader.addEventListener(Event.COMPLETE, gbCompleteHandler);
gbookLoader.load(gbookRequest);
return true;
function gbCompleteHandler(event:Event):void {
var variables:URLVariables = event.currentTarget.data as URLVariables;
// if the server returned the value of isValidLogin with a value of 1...
if (variables.valid == 1) {
// set the status_lbl Label to a "success" message.
// Typically here you'd do a gotoAndPlay or set any local variables
// related to a successful login.
aviso.htmlText = "<font color=\"#009900\"><b>Mensagem enviada e a aguardar aprovação.</b></font>";
// else the login information wasn't valid,
// therefore display an error message in the status_lbl Label instance.
} else {
aviso.htmlText = "<font color=\"#EFDFDC\">Ocorreu um erro no envio da sua mensagem.</font>";
mail.text="";
alias.text="";
mensagem.text="";
titulo.text="";
this is my php file
<?php include_once("../admin/includes/db_access.php"); ?>
<?php
include("../admin/includes/funcs.inc.php");
if (!function_exists("GetSQLValueString")) {
function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
$theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
switch ($theType) {
case "text":
$theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
break;
case "long":
case "int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
$theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
break;
return $theValue;
if ($_POST) {
echo 'valid=1';
insertSQL ="INSERT INTO recolha_gbook (datime, `alias`, titulo, mensagem, mail, del, modif, datem, sys, agent, ip, valido) VALUES (date("Y-m-d H:i:s"),$_POST['alias'],$_POST['titulo'],$_POST['mensagem'],$_POST['mail'],0,1,date("Y-m-d H:i:s"),GetOs(getenv('HTTP_USER_AGENT')),GetBrowser(getenv('HTTP_USER_AGENT')),getenv('REMOTE_ADDR'),0)",
mysql_select_db($database_adcms, $adcms);
$Result1 = mysql_query($insertSQL, $adcms) or die("valid=0");
echo "valid=1";
}else{
echo "valid=0";
you need cross-domain permissions to load that php or use a local php file to call it or use a relative path if that's not a cross-domain file.
i just create a crossdomain.xml
copied it to the directory where is the flash project
<?xml version="1.0"?>
<!DOCTYPE cross-domain-policy SYSTEM "http://www.macromedia.com/xml/dtds/cross-domain-policy.dtd">
<cross-domain-policy>
<allow-access-from domain="*" />
</cross-domain-policy>
made it readable, but its not working
thanks
Pedro
you need to instruct flash to load that file:
Security.loadPolicyFile("http://www.whatever.com/crossdomain.xml");
still not working
[SWF] D:\iagora\novoguest\gbook_v5.swf - 99717 bytes after decompression
Connection to http://localhost/novo_guest/crossdomain.xml halted - not permitted from file:///D|/iagora/novoguest/gbook%5Fv5.swf
thanks
Pedro
if you're testing local, give your local file permission:
http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager04a.html
